The Best Wireless Headphones for TV
This time of year we always get lots of questions about finding the best headphones for TV listening.
There are probably around a million wireless headphone choices for TV out there (give or take), but here at Headphone.com we're audiophiles and, for us, sound quality is always number one on the list.
Over the years, we have reviewed a plethora of 'TV-oriented' wireless headphones from many makers. We keep coming back to the Sennheiser 'RS' model line which we think offers some of the best products in this highly specialized category.
Using wireless headphones for TV has several benefits. Along with handy wire-free convenience and improved dialogue / speech intelligibility (more on that below), some base transmitter stations can broadcast to two wireless headphones at the same time. The ability for each viewer to set the TV volume to their individual preference on their own headphone is a huge plus for helping things go smoothly in the household.
Wireless Headphones And Your TV Can Easily Work Together!
Your TV has either 'digital' or 'analog' audio output connections - sometimes both. This factor will determine what type of wireless headphones, cables or accessories you will need for your particular television.
For example, if your TV only has analog RCA-type audio connections (bottom inset; far left), it makes sense to choose an analog wireless model like the Sennheiser RS 135 since you won't be making use of upscale digital connection features - meaning you'll save yourself a ton of dough!
However, many modern TVs have only a digital audio output available which means you will need to find a base station unit that can accept that type of input from your television.
We think the 'sweet spot' in the Sennheiser RS wireless headphone series is the RS 175 model which offers audio connections of all types - both analog and digital - and is compatible with most TVs. It also sounds significantly better than the less expensive RS135 model due to its digital-based audio transmission system.
How To Connect Wireless Headphones To Your TV (It's Easy!)
Wireless TV headphones contain a miniaturized receiver that communicates directly with the base station. The base station connects to your TV via either an analog cable or a digital cable method, depending on your particular television. Some new flat screen TVs may only offer digital audio output capability.
Digital connection methods are either via an Optical or a Coaxial cable (shown top inset, right panel). Analog connection methods are either via RCA stereo dual plugs [usually red and white] or from the TV's 'mini' line-out jack (shown top inset, left panel). Whether connected via either digital or the analog RCA method, the internal TV speakers will remain adjustable via the normal TV volume control, while the headphone listener will use the independent volume control on the headphones. Although the sound quality won't be as good as via digital connection methods, you can plug the base station directly into the headphone jack (1/8″ or 3.5 mm mini-plug) on your TV. This plug type will often have a little headphone image above it (see top inset; left panel). This method is always an analog connection that will turn the TV speakers OFF. Some older televisions may not have any other audio connection method. In this situation, the headphone plug connection might be the only way to use wireless headphones with that type of TV.
Improve TV Dialogue and Speech Intelligibility With Wireless Headphones
An important aspect of high-quality TV and movie watching is speech intelligibility. In other words, how clearly you can hear and understand the dialogue between the characters or during narrative voice-overs.  One major benefit of wireless TV headphones is that many of these models are optimized for the best speech intelligibility possible. For example, the frequency range that determines audible differences between human “S” and “F” vocal sounds occurs between 3,000 kHz and 7,000 kHz. This is often called the 'vocal presence' region. Many built-in TV speakers - especially flat-panel TVs -  have lousy fidelity in this frequency range. And turning up the volume simply increases distortion modulation and mid-frequency harmonics, further smearing the dialogue. Top wireless TV headphones are able to provide improved clarity in these important speech frequencies. They also allow others in the room to listen at a regular volume via the TV speakers if so desired. Considering Non-Wireless and/or Standard 'Wired' Headphones for TV
Of course, you can use any standard 'wired' set of headphones if your TV has a built-in headphone jack, although perhaps a headphone extension cord may be needed. On most TVs with a headphone jack, directly connecting headphones automatically turns off the TV speakers and you'll be able to adjust the headphone volume with the volume control for the TV set itself.
Here are links to buy the wireless headphones mentioned in the article:
Click Here For a Complete List of Our Best Wireless Headphones for TV
Buying guidesHow to's
22 comments
N. Sheehan
N. Sheehan
You ought to try the two models in the Sony range, the mdrd 6500, and the mdr hw700 ds. They both have dolby surround, and dts processing, and blow the Sennheisers TO BITS! I say this as a previous owner of a set of rs175’s. They were decent, but had a simple “surround” facility, and did go a phase of connection drop out issues, which did clear up. Sennheiser cans are largely seriously over rated, in my experience. I have owned several pairs, and they have varied from ok (rs 175) to awful (hd 598).
Archer
Archer
Very good info. Lucky me I discovered your site by chance (stumbleupon).
I’ve book-marked it for later!
antipsychotic drug (Syreeta)
Ramnarayan
Ramnarayan
Hi,
Can somebody explain to me if these TV headphones are meant for viewing TV with a partner/s…i.e., for more than one viewer? After all TV is more fun when you have two people watching a TV show together!
Lee Ann Ferguson
Lee Ann Ferguson
I stumbled across your page while looking for new headphones for my dad who is hard of hearing. He’s been buying TV Ears brand for years. But they break all the time and not cheap. Honestly didn’t know anyone else makes them! The brand you mentioned, are they good for someone who wears hearing aids? Appreciate your post. Thank you
Alex McNeil
Alex McNeil
I agree with going with the Sennheisers. Great for home use, high quality, and the connection quality is excellent.
kent mccoy
kent mccoy
total mess out there with wireless tv headphones—just sent a pair of IR Unisar J3 headphones back to amazon—had to use a digital to analog converter but still nothing but silence or roaring static—IR transmitter would come on and then fade after a couple of minutes then huge static—-
Joe Mahalak
Joe Mahalak
I stay at hotels and cannot get earphones to work on the tvs. Both tvs had analog rca red and white plugs. Is there a tv setting that has to be activated on hotel tvs before they will work?
Hans
Hans
Dear Brian,
your LG OLED55E6P TV seems to have a HDMI-connector. You can get an adapter from HDMI to cinch connectors ( or RCA ),
available at EBAY like this: http://www.ebay.de/itm/like/282136810092?lpid=106&chn=ps&ul_noapp=true.
The base of my wireless TV-hedphone is connected via such a device with my Samsung TV.
best regards
Hans
Cliff
Cliff
Congrats on your TV purchase. Looks like you have an Optical out – so you would have to purchase a headset that has this type of input (RS 175 as shown above) OR buy a digital converter. Such as the one shown here https://www.sharperimage.com/si/view/product/Digital+Audio+Connector+for+the+Wireless+TV+Speaker/205197
Brian Van Hereweghe
Brian Van Hereweghe
I just bought an LG OLED55E6P TV. I used wireless headphones on my old sharp TV but have no idea how to get wireless headphones to work on this LG TV. Don’t know how or where to connect. Have any ideas? Please email if you have a solution.
Thanks for your time Brian
N. Sheehan
N. Sheehan
Archer
Archer
Ramnarayan
Ramnarayan
Hi,
Lee Ann Ferguson
Lee Ann Ferguson
Alex McNeil
Alex McNeil
kent mccoy
kent mccoy
Joe Mahalak
Joe Mahalak
Hans
Hans
Dear Brian,
best regards
Hans
Cliff
Cliff
Brian Van Hereweghe
Brian Van Hereweghe
Cliff
Cliff
Brian Van Hereweghe
Brian Van Hereweghe
Leave a comment
All comments are moderated before being published
