Astell&Kern AK70 64GB Portable High-Resolution Audio Player and USB DA - headphones.com
Astell&Kern AK70 64GB Portable High-Resolution Audio Player and USB DAC
Color
Misty Mint
The AK70 Portable High-Resolution Audio Player and USB DAC from Astell&Kern uses the Cirrus Logic CS4398 chip and supports 24-bit/192 kHz bit-to-bit type playback. The 64GB of on-board storage can be expanded with a microSDXC card (maximum 128GB).
32-bit audio is downsampled using a sample-rate converter, and DSD 64/128 can be played back through conversion to PCM. The AK70 player sports 3.5mm, 3-pole unbalanced and 2.5mm, 4-pole balanced headphone jacks. The balanced output is capable of removing noise (common mode noise) that can occur in signal and inverting amplifier signal, and has the strength of increasing output due to its double transmitting signals.
The audio player supports USB audio digital out and allows you to connect diverse digital-input portable amps through USB. It can transfer DSD in native through DoP and also convert 5.6 MHz DSD into PCM for output to portable amps that do not support DoP.
The AK70 music player can be used with a USB DAC that can double as an embedded sound card by connecting with a Windows or Mac computer through the USB port. The AK70 will simplify the playback of DSD files on your computer.
The player is designed with an oblique angle on one side of the body so that it can fit the contour of the user's thumb. The volume wheel is designed to be protruding slightly from a concave surface so that you can control volume with a simple motion of sliding your finger up and down. In addition, the player comes in an anodized aluminum casing.
Specs
Operating System Not specified by manufacturer
Type Flash Memory
Capacity 64 GB
Memory Card Slot Yes
Flash Media Slot 1x microSD
Display 3.3" LCD Touchscreen
480 x 800 Pixel Resolution
FM Tuner No
FM Recording No
Voice Recording No
Data Storage No
Photo Capture No
Photo Viewing No
Video Recording No
Video Playback No
Formats Supported Audio: WAV, FLAC, WMA, MP3, OGG, APE (Normal, High, Fast), AAC, ALAC, AIFF, DFF, DSF, DSD (5.6 MHz; converts to PCM)
Frequency Response 20 Hz - 20 kHz
Impedance
Signal to Noise Ratio 116 dB
Wireless Bluetooth 4.0
Wi-Fi (802.11b/g/n)
Connections Micro-USB 2.0
1x 1/8" (3.5mm) Stereo Headphone
2.5 mm Audio Output
Battery 1x Built-In Rechargeable Lithium-Polymer Battery 2200 mAh
System Requirements Operating System
Windows XP, 7, 8
Mac OS X OS X 10.7
Temperature Not specified by manufacturer
Dimensions (WxHxD) 2.3 x 3.8 x 0.5" / 58.4 x 96.5 x 12.7 mm
Weight 4.6 oz / 130.4 g
Packaging Information
Package Weight 0.65 lb
Box Dimensions (LxWxH) 5.2 x 3.8 x 1.9"
In The Box
Astell&Kern AK70 64GB Portable High-Resolution Audio Player and USB DAC (Misty Mint)
Limited 1-Year Warranty
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
Free Headphone Stand With Your First Order
