Close Cart
Your cart is currently empty.
Browse:
Astell&Kern AK T1p Astell&Kern AK T1p
  • Astell&Kern AK T1p
Astell&Kern AK T1p
Astell&Kern AK T1p
$999.00 $699.00
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    Developed through a collaboration with Beyerdynamic, the Astell&Kern AK T1p Special Edition Headphones use high-efficiency Tesla technology in a semi-open over-ear design to deliver a frequency response of 5 Hz to 50 kHz into a 32 ohm load with a maximum SPL of 126 dB. The headphones can be used with portable high-resolution audio devices such as mobile players, smartphones, tablets, and more.
    Furthermore, an additional 2.5mm balanced cable for Astell&Kern portable audio devices is included with a 3.5mm audiophile-grade cable. Just like all of Beyerdynamic’s headphones, the AK T1p is handmade in Germany with the utmost attention to detail.
    Ideal for High-Resolution Playback
    With its open design, the AK T1p is particularly capable when it comes to reproducing the full musical wealth offered by high-resolution audio files. Instruments and voices separate from the headphones and create a virtual soundstage.
    Perfection “Made in Germany”
    The AK T1p is manufactured entirely by hand in Heilbronn. Additional attenuation at the heart of the Tesla driver eliminates even the last traces of resonance in the high frequency range. Beyerdynamic has also optimized the geometry of the baffle design and replaced the single-layer baffle material with a more stable, high-tech compound. This reduces the vibration of the material to a minimum, which in turn delivers even clearer sound combined with precise bass.
    Mobile Sound Experience Throughout your Home
    Thanks to the 32 ohm Tesla technology, the output of the AK T1p when paired with mobile players, smartphones or tablets is significantly louder than the T1 with its 600 ohm transducers. It thus becomes a universal listening device - be it when chilling on the sofa, out on the terrace, or even in bed. Discerning audiophiles and digital natives are now able to carry their high-end systems with them at all times.
    Compatible with All Player Devices
    Owners of one of Astell&Kern’s high-end players can connect the AK T1p directly to the symmetrical output of their portable device using the supplied cable with its 2.5mm jack plug. As a result, the lead has virtually no impact on the sound, thus allowing listeners to enjoy studio masters with 24-bit resolution or high-res files in DSD format in their full, pure glory - just as the sound engineer in the studio intended. A standard 3.5mm jack cable is supplied for all other players.
    *Headphones.com is very pleased to announce that you have even more options to pay for your Astell&Kern AK T1p headphones! Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
