Close Cart
Your cart is currently empty.
Browse:
Astell&Kern Jerry Harvey Audio Roxanne II Astell&Kern Jerry Harvey Audio Roxanne II
  • Astell&Kern Jerry Harvey Audio Roxanne II
$1,999.00
  • Variable-Bass Output Adjustable from Cable
  • FreqPhase Technology / Stainless-Steel Tube Waveguide
  • Soundrive Quad-Driver Technology
  • 4-pin Cable Connection with Machined-Aluminum Locking Collar
  • Casings machined from a single piece of aluminum
  • Proprietary Driver Design
Headphones.com is stoked to be accepting NANO, Bitcoin, Ethereum, Litecoin and many more cryptocurrencies!
  • Description
    Developed through collaboration with Jerry Harvey Audio, the Astell&Kern Roxanne II In-Ear Monitor Headphones allow you to hear the music how the recording artist and mix engineer intended it to sound, utilizing audio devices such as mobile players, smartphones, tablets, and more.
    Featuring twelve custom-made dual-low, dual-mid, and quad high-balanced armature drivers per side, the in-ear monitors have a variable-bass output, which is adjustable from the cable, and delivers frequency ranges from flat bass response up to +13 dB (10 to 100 Hz).
    Some additional features are an integrated 4th-order crossover, triple bore with stainless-steel tubing, noise isolation of -26 dB, and the included Moon Audio IEM cables; one 3.5mm unbalanced and one 2.5mm balanced connection. Five sets of silicone eartips, a screwdriver, cleaning brush, and a carry case are also included.
    Full Metal Jacket
    Each body, cap, and sound bore is machined from one solid block of aluminum with a carbon fiber logo-plate insert.
    This series of (In-Ear Monitors) IEM’s were designed to be used as a mastering-reference tool because the high driver was designed for optimum top-end extension with minimal distortion. The mid driver is perfectly flat from 10 Hz to 5 kHz. The low driver is designed for steeper low-pass frequencies with virtually no distortion.
    SoundrIVe Technology (Quad-Driver Technology)
    Roxanne Ⅱ was equipped with SoundrIVe technology, using Jerry Harvey Audio’s proprietary quad drivers. Roxanne Ⅱ has a triple-quad driver (12 drivers) configuration that offers a wide frequency range.
    FreqPhase corrects time and phase of multiple drivers. The waveguide ensures each driver signal arrives within 0.01 ms, resulting in a phase-coherent IEM.
    User-controlled low-frequency drivers have an adjustable bass (0 - +10 dB). Frequency ranges from flat-bass response up to +10 dB (10 to 100 Hz).
    A 4-pin cable connection with a machined aluminum-collar mechanism provides a more secure and strong connection with the earpiece and will also help to protect it from sweat and dust.
  • Tech Specs
    Type
    Universal fit IEM (In-Ear Monitor)
    Driver Unit
    Custom-made proprietary balanced-armature driver (12 BA per side)
    Frequency Response
    10 Hz to 23 kHz
    Input Sensitivity
    119 db @ 1 mW
    Impedance
    15 Ohms
  • In The Box
    • Astell&Kern Jerry Harvey Audio Roxanne II In-Ear Monitor Headphones
    • 5 x Sets of Silicone Eartips
    • Screwdriver
    • Cleaning Brush
    • 2.5 mm to 2.5 mm Balanced Cable
    • 3.5 mm to 2.5 mm Unbalanced Cable
    • Carry Case
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Full Metal Jacket
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
