Close Cart
Your cart is currently empty.
Browse:
Audeze iSine 10 Audeze iSine 10
  • Audeze iSine 10 Headphones Audeze Standard Cable
Audeze iSine 10
Audeze iSine 10
$349.00
  • One of the world's first planar magnetic in-ear headphones
  • Open-back design allows for a mind-blowing, spacious soundstage
  • 30mm Planar Magnetic Drivers in each earpiece allowing for dynamic range and detailed sound
  • Detachable 59-inch flat audio cable with a 3.5mm plug
  • Uniforce™ diaphragm technology helps reduce distortion
  • *Lightning version includes cipher cable with built-in DAC and headphone amp
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The Audeze iSINE 10 In-Ear Headphones with Lightning and Standard Cables or just Standard Cables feature Fluxor magnets, large 30mm planar magnetic diaphragms, and a 10 Hz to 50 kHz frequency response that deliver precise control and fast response times without distortion so music sounds alive. They can be used with iPods, iPhones, iPads, or any device with a 1/8" audio jack.
    The headphones barely weigh .71 oz (20 grams), and are built with power-enhancing Fluxor magnets that double the magnetic driving force on the ultra-thin diaphragms. Their Uniforce voice-coil technology delivers an accurate in-ear headphone experience with distortion less than 0.1% overall, even at high volumes. In addition, the included Cipher Lightning cable contains a high-quality inline amplifier, a digital-to-analog converter, and DSP, which delivers a vivid, natural sound.
    Furthermore, customize your sound in real time with the Audeze iOS App. It features two presets to personalize your music playback. There is a 10-band equalizer that changes EQ in real time. You can refine the bass levels and tame the highs on peaky recordings. Then you can save two EQ curve presets that travel with the cable when switching devices.
    *Headphones.com is very pleased to announce that you have even more options to pay for your MrSpeakers AEON Flow Open headphones. Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
  • Tech Specs
    Style
    In-ear, universal fit
    Transducer Type
    Planar magnetic, semi-open
    Magnetic Structure
    Fluxor
    Magnet Type
    High-grade neodymium
    Diaphragm Type
    Ultra-thin Uniforce
    Transducer Size
    1.2" (30 mm)
    Maximum Power Handling
    3 W
    Maximum SPL
    >120 dB
    Frequency Response
    10 Hz to 50 kHz
    Total Harmonic Distortion (THD)
    <0.1% @ 100 dB
    Impedance
    16 Ohms
    Cable Type
    Non-microphonic
    Dimensions
    Not specified by manufacturer
    Weight
    0.71 oz (20 g) without cable
  • In The Box
    • Audeze iSINE 10 In-Ear Headphones
    • 4.9' Audio Cable, 1/8" Stereo Plug Input to 2-Pin Plug Output
    • 4.9' Cipher Cable, Lightning Plug Input to 2-Pin Plug Output
    • Limited 3-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
