Audio-Technica ATH-DSR7BT
Regular price $299.00
Go wireless with the Audio-Technica ATH-DSR7BT Wireless Over-Ear Headphones. These on-ear headphones have 45mm drivers that deliver frequencies from 5 Hz to 40 kHz. They connect to your device via Bluetooth 4.2 and can remember up to eight devices, connecting automatically to the last one used. NFC is on-board for easy pairing, and LED indicators display connection and battery status.
The headphones have a microphone for calls as well as volume and playback controls. Memory foam-padded earcups and headband improve comfort. The lithium-ion polymer battery lasts for up to 15 hours or up to 1000 hours on standby; it takes approximately four hours to recharge with the included USB cable.
Pure Digital Drive
Pure Digital Drive allows these headphones to operate without using the digital/audio converter found in traditional wireless headphones. It uses Trigence Semiconductor’s Dnote chipset to process wireless digital audio signals, relying on the chipset’s digital pulses to move the voice coil and diaphragm.
True Motion Drivers
The 45mm True Motion Drivers use specially designed diaphragms and lightweight bobbin-wound voice coils to reproduce sound. Acoustic resistors control airflow around the diaphragm for balanced sound. The assembly is housed in a layered aluminum chassis to reduce unwanted resonance and isolate the circuitry from the housing’s acoustic space.
Codecs
Compatible with Qualcomm aptX HD, aptX, AAC, and SBC codecs for wireless transmission with a resolution up to 24-bit/48 kHz.
Hi-Resolution Audio
When connected to a computer or digital playback device with the included 6.6' audio/charging cable, the headphones can reproduce Hi-Res audio for a more detailed listening experience.
*Headphones.com is very pleased to announce that you have even more options to pay for your Audio-Technica ATH-DSR7BT headphones! Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
Customer Reviews
Based on 1 review Write a review
