Free Shipping on every order | 365-day returns | No Tax
0
Your Cart is Empty
Audio-Technica ATH-DSR9BT Wireless Over-Ear Headphones
Color
Silver
ATH-DSR9BT
The Best Wireless Headphones Available
Go wireless with the Audio-Technica Wireless Over-Ear Headphones with Pure Digital Drive. These on-ear headphones have 45mm drivers that deliver frequencies from 5 Hz to 40 kHz. They connect to your device with Bluetooth 4.2 and can remember up to eight devices, connecting automatically to the last one used. NFC is on-board for easy pairing, and LED indicators display connection and battery status.
The headphones have a microphone for calls as well as volume and playback controls. Heat-reactive, memory foam-padded earcups and headband improve comfort. The lithium-ion polymer battery lasts for up to 15 hours or up to 1000 hours on standby and takes approximately four hours to recharge with the included USB cable.
Pure Digital Drive
Pure Digital Drive allows these headphones to operate without using the digital/audio converter found in traditional wireless headphones. It uses Trigence Semiconductor's Dnote chipset to process wireless digital audio signals, relying on the chipset's digital pulses to move the voice coil and diaphragm.
True Motion Drivers
The 45mm True Motion Drivers use specially designed diaphragms with DLC (diamond-like carbon) coating and four-core twisted OFC-7N voice coils to reproduce sound. Acoustic resistors control airflow around the diaphragm for balanced sound. The assembly is housed in a layered aluminum chassis to reduce unwanted resonance and isolate the circuitry from the housing's acoustic space.
Codecs
Compatible with Qualcomm aptX HD, aptX, AAC, and SBC codecs for wireless transmission with a resolution up to 24-bit/48 kHz.
Hi-Resolution Audio
When connected to a computer or digital playback device with the included 6.6' audio/charging cable, the headphones can reproduce Hi-Res audio for a more detailed listening experience.
Wireless
Connectivity Bluetooth 4.2
Output Power Bluetooth Specification Power Class 2
Frequency 2.402 to 2.480 GHz
Supported Bluetooth Profiles A2DP, AVRCP, HFP, HSP
Bluetooth Codecs aptX HD audio, aptX audio, AAC, SBC
Content Protection SCMS-T
Sample Rates 44.1 and 48 kHz
Bit Rates 16-bit, 24-bit when using aptX HD codec
Transmission Frequency 20 Hz to 20 kHz
Wireless Range 33' (10 m)
Memory Up to 8 devices
NFC Yes
Audio
Driver Size 1.8" (45.0 mm)
Voice Coil OFC-7N
Frequency Response 5 Hz to 45 kHz
Impedance 38 Ohms
Sensitivity 97 dB/mW
Cable
Cable Length 6.6' (2.0 m)
Connectors micro-USB to USB
Microphone
Type Condenser, omnidirectional
Sensitivity -44 dB (1 V/Pa at 1 kHz)
Frequency Response 50 Hz to 4 kHz
Battery
Battery Type Lithium-ion polymer, 3.7 VDC
Battery Life In-Use: Up to 15 hours
Standby: Up to 1000 hours
Battery Charge Time Approximately 4 hours
Minimum System Requirements
Connector USB 2.0 Type-A
CPU Intel Core 2 processor running at 2.2 GHz or faster, or an equivalent AMD processor
RAM 32-bit: At least 2 GB
64-bit: At least 4 GB
Operating Systems Windows 7, 8, 8.1, 10
Mac OS X El Capitan (10.11)
Sample Rates 44.1, 48, 96 kHz
Bit Rates 16- and 24-bit
Frequency Response 5 Hz to 40 kHz (during 24-bit/96 kHz playback)
General Specs
LED Indicator Yes
Operating Temperature 41 to 104°F (5 to 40°C)
Dimensions Not specified by manufacturer
Weight 11.1 oz (315.0 g)
Packaging Info
Package Weight 2.7 lb
Box Dimensions (LxWxH) 10.1 x 8.9 x 3.8"
  • Audio-Technica Consumer Wireless Over-Ear Headphones with Pure Digital Drive
  • Micro-USB to USB Charging/Audio Cable
  • Hard Case
  • Cable Pouch
  • Limited 2-Year Warranty
Pure Digital Drive
True Motion Drivers
Codecs
Hi-Resolution Audio
Wireless
NFC Yes
Audio
Voice Coil OFC-7N
Impedance 38 Ohms
Cable
Microphone
Battery
General Specs
LED Indicator Yes
Packaging Info
  • Hard Case
  • Cable Pouch
Customer Reviews
Based on 2 reviews
100%
(2)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
F
F.K.M.
5/5
D
D.S.
Surprise surprise
I ordered this pair of wireless headphones because I wanted a wireless set with the best sound possible. Being bluetooth, I expected some compromise in sound quality. Boy was I wrong. I am blown away by the musicality, dynamism, and precision of these headphones. I have owned sennheiser HD800's, as well as several other high end headphones. Yes, you can probably find something that will out do these headphones if you hyper focus on some narrow band of audio pixels. But oh my, if you are mostly into music for music's sake these are amazingly musical. The sound stage is breathtaking. You know you are onto something when a new set of headphones has you going back over your music collection to hear old favorites with fresh ears. One of my pet peeves with many setups is what I call orchestral smearing: instruments losing their individuality in a blurry wall of sound. Not happening here, Solo voices on classical recordings have "air" around them, Bass extension is authoritative without being pushy or exaggerated and tight, tight, tight. Bring on those organ solos. Really, these headphones are a technical marvel, and whatever they are doing with the "direct digital drive" is not a gimmick. I would put these headphones up against wired headphones costing 4 times as much. Oh, and they are acceptably comfortable, not as comfortable as the HD800, but nothing is. Obviously much in the world of high end musical technology depends on your taste. This pair nails mine.
Subscribe
