Close Cart
Your cart is currently empty.
Browse:
AudioQuest Diamond 4K HDMI AudioQuest Diamond 4K HDMI
  • AudioQuest Diamond 4K HDMI Cables AudioQuest 0.6M
$1,029.95
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    Features :
    • Solid 100% Perfect-Surface Silver Conductors
    • Foamed-Polyethylene Insulation
    • Carbon-Based 3-Layer Noise-Dissipation System
    • Dielectric-Bias System
    • Directionality
    • High Speed Data Capacity
    The Diamond HDMI from AudioQuest incorporates AudioQuest’s highest-performance, lowest-distortion Perfect-Surface Silver conductors. Silver is known for its high conductivity and its “colorless” sonic presentation.
    All AudioQuest HDMI cables up to 8 meters meet or exceed the 18 Gbps maximum data rate for HDMI and are approved High Speed with Ethernet cables. This means that all AudioQuest cables up to 8 meters are capable of transmitting 100% of the data required for all of HDMI’s current audio/video features including multichannel high-resolution audio, 1080p and 4K video, and 3D video from Blu-ray. All AudioQuest HDMI cables will deliver 100% of the data required for 120Hz/240Hz/600Hz displays.
    Perfect-Surface Technology applied to extreme-purity silver provides unprecedented clarity and dynamic contrast. Solid conductors prevent strand interaction, a major source of cable distortion. Extremely high-purity Perfect-Surface Silver minimizes distortion caused by the grain boundaries that exist within any metal conductor, nearly eliminating harshness and greatly increasing clarity compared to OFHC, OCC, 8N and other coppers.
    Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then released as distortion. Diamond HDMI uses air-filled Foamed-Polyethylene Insulation because air absorbs next to no energy and Polyethylene is low-loss and has a benign distortion profile. Thanks to all the air in Foamed-PE, it causes much less of the out-of-focus effect common to other materials.
    100% shield coverage is easy. Preventing captured RF Interference from modulating the equipment’s ground reference requires AQ’s Noise-Dissipation System. Metal and Carbon-Loaded synthetics prevent most RFI from reaching the equipment’s ground plane.
    All insulation slows down the signal on the conductor inside. When insulation is unbiased, it slows down parts of the signal differently, a big problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes both energy storage in the insulation and the multiple nonlinear time-delays that occur. Sound appears from a surprisingly black background with unexpected detail and dynamic contrast. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check.
    Directionality
    All audio cables are directional. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. All signal conductors controlled for digital-audio direction in AudioQuest HDMI cables, and care is even taken to run the conductors used in the Audio Return Channel in the opposite direction to ensure the best performance for that application. Arrows are clearly marked on the connectors to ensure superior sound quality.
    HDMI standards and capabilities have improved significantly since DVI first evolved into HDMI. All generations are backward compatible. However, not all previous HDMI cables can transmit the full 18Gbps of data required to optimize today’s HDMI 2.0 equipment. While there is currently no 4K/60 4:4:4 software requiring the full 18Gbps capability of HDMI 2.0, some sources (UHD Blu-ray players) can be set to upsample, requiring 18Gbps capability. The most important thing to know and understand is that all AudioQuest HDMI cables up to 8 meters are guaranteed to exceed the requirements for all possible HDMI 2.0/HDCP 2.2 data streams, including 4K UltraHD, HDR, and Blu-ray Ultra HD.
    *Headphones.com is very pleased to announce that you have even more options to pay for your AudioQuest HDMI cables! Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
  • Reviews
Features :
  • Directionality
Directionality
