AudioQuest
AudioQuest Pearl 4K HDMI
AQ173
Regular price $26.95
1 in stock
Free Shipping
365 Day Returns
No Tax
Features :
  • Solid Long-Grain Copper Conductors
  • Foamed-Polyethylene Insulation
  • Directionality
  • High Speed Data Capacity
The Pearl HDMI from AudioQuest embodies all of AudioQuest’s core philosophies on cable design. It employs solid Long-Grain Copper conductors, Solid High-Density Polyethylene Insulation, and precise geometry. Specific attention has been paid to maximizing the performance of HDMI, and indeed, AudioQuest’s HDMI cables push sonic performance to new levels.
All AudioQuest HDMI cables up to 8 meters meet or exceed the 18 Gbps maximum data rate for HDMI and are approved High Speed with Ethernet cables. This means that all AudioQuest cables up to 8 meters are capable of transmitting 100% of the data required for all of HDMI’s current audio/video features including multi-channel high-resolution audio, 1080p and 4K video, and 3D video from Blu-ray. All AQ HDMI cables will deliver 100% of the data required for 120Hz/240Hz/600Hz displays.
Solid conductors eliminate strand-interaction distortion. Pearl’s solid Long-Grain Copper allows a smoother and clearer sound than cables using regular OFHC (Oxygen-Free High-Conductivity) copper. OFHC is a general metal industry specification regarding “loss” without any concern for distortion. LGC has fewer oxides within the conducting material, less impurities, less grain boundaries, and definitively better performance.
Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then released as distortion. Pearl HDMI uses air-filled Foamed-Polyethylene Insulation because air absorbs next to no energy and Polyethylene is low-loss and has a benign distortion profile. Thanks to all the air in Foamed-PE, it causes much less of the out-of-focus effect common to other materials.
Directionality
All audio cables are directional. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. All signal conductors controlled for digital-audio direction in AudioQuest HDMI cables, and care is even taken to run the conductors used in the Audio Return Channel in the opposite direction to ensure the best performance for that application. Arrows are clearly marked on the connectors to ensure superior sound quality.
HDMI standards and capabilities have improved significantly since DVI first evolved into HDMI. All generations are backward compatible. However, not all previous HDMI cables can transmit the full 18Gbps of data required to optimize today’s HDMI 2.0 equipment. While there is currently no 4K/60 4:4:4 software requiring the full 18Gbps capability of HDMI 2.0, some sources (UHD Blu-ray players) can be set to upsample, requiring 18Gbps capability. The most important thing to know and understand is that all AudioQuest HDMI cables up to 8 meters are guaranteed to exceed the requirements for all possible HDMI 2.0/HDCP 2.2 data streams, including 4K UltraHD, HDR, and Blu-ray Ultra HD.
*Headphones.com is very pleased to announce that you have even more options to pay for your AudioQuest HDMI cables! Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
