Close Cart
Your cart is currently empty.
Browse:
Beyerdynamic DT 880 250 ohm Beyerdynamic DT 880 250 ohm
  • Beyerdynamic DT 880 250 ohm
$249.99
  • Hi-fi headphone, 250 ohm, semi-open system
  • Single-sided cable
  • Stereo jack plug 1/4" / 6.35 mm
  • Includes volume control
  • Cable length 5m
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    At the far end of the spectrum from folks who like strong bass punch are listeners who want their audio presented with light, detailed buoyancy; enter the Beyerdynamic DT-880. Capable of rendering the sound of a fingernail stroke on gut, the stiction of rosin on a cello string, and the airy spaciousness of sound bouncing off cathedral walls, these venerable audiophile cans deliver dynamics and depth with extraordinary clarity. The DT-880 may also be re-wired for XLR balanced operation. Choose between high impedance 250 Ohm or the more efficient 32 Ohm version.
    Germany's Beyerdynamic has offered up a real contender for world's very best well-priced headphone with the DT880. Although these cans are ever-so-slightly more forward-sounding than what we can call absolutely 'neutral', the DT880 serve up a wonderfully engaging audiophile headphone listening experience--absolutely TONS of clarity, crisply-rendered musical detail throughout all frequency ranges, and a very precise, deeply layered soundstage image and, thankfully, not a harsh note to be found! The DT880's mids and upper bass really hold together very well, so overall a seamless and smooth-sounding tonal presentation.
    Amazingly expressive dynamics, superbly controlled highs, plus a sweet mid-range snap make the DT880 a very well-balanced can, but perhaps not the most ideal headphone choice for the heavy bass-loving hip-hop/rap/electronica crowd since the DT880 doesn't quite muster up the hefty bottom-end response required for anchoring modern funkitude. We think you'll love these headphones if you seek clear, clean sonics with plenty of airy musical detail, quick dynamics, excellent upper treble range extension, and a lively, ultra-open soundstage presentation. They are especially strong audio performers for classical, symphonic, chorale, chamber, and acoustic folk and jazz recordings.
    The DT880 also seem particularly good at speech intelligibility, female vocal textures, and film soundtrack detail recovery for truly immerse movie/DVD watching and will deliver a superb high-end home theater personal listening experience. Moreover, the DT-880 have become big faves amongst audio professionals doing analytical recording work who demand timbral accuracy, instrumental detail, and precise musical clarity above all else. By the way, we believe the recently revised DT880 to be just a smidgen stronger in the low-mids/bass than previous DT880 editions--probably due to the extra damping material in the earpiece housing and (maybe?) the 'softer', more rounded earcup shape. The revised DT880 headphone also features a simpler plastic/alloy headband design and some fairly minor cosmetic re-workings. Please remember that about 100-200 listening hours are required for the large-driver DT880 to fully 'burn-in' and sound its very best.
    The current edition of the Beyerdynamic DT880 now comes packaged in a re-usable soft-sided protective foam-padded box. The earpads are made of a very soft and plush grey velour material with a simple plastic/metal alloy headband that has also been slightly re-designed. Both parts are easily replaced with Beyerdynamic after-market replacement parts if they ever wear out. The DT880 provides multiple fit adjustments for great comfort and the headphones feel really solidly well-built to boot. They'll certainly take a fair beating around the home/office and keep right on trucking that killer Beyerdynamic sound for a long time to come. The 3-meter long (approx 9-ft) single-sided straight cord exits from the left earcup and terminates to a 1/8' (3.5mm) mini-plug.
    • Cable length 5m
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
  • Cable length 5m
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
