Blue Ella Planar Magnetic Over-Ear Closed-Back Headphones with Built-I - headphones.com
Blue Ella Planar Magnetic Over-Ear Closed-Back Headphones with Built-In Amplifier
No reviews
Color
Silver
The Blue Ella Planar Magnetic Headphones are the only headphones that combine the transparent detail of planar magnetic drivers with the impact of dynamic technology to deliver awe-inspiring sound quality and intense emotion. Ella maximizes the sound of your music using advanced planar magnetic drivers, a built-in audiophile amplifier and large, high-capacity cabinets. And the revolutionary ergonomic fit ensures optimal sound isolation and comfort for the most immersive listening experiences. Whether you’re enjoying the Zeppelin reissue box sets, Pink Floyd on 180-gram vinyl, Radiohead collector’s edition remasters or Neil Young on high-resolution digital, Ella’s radical headphone design reveals new detail in songs you’ve heard a thousand times.
Blue's planar magnetic technology provides the perfect artisanal blend of accuracy and impact. Ella’s 50mm x 50mm drivers feature a planar membrane that’s less than 50 microns thin and self-tensioned for fast response and extreme accuracy. The massive driver enclosures are fashioned after high-end speaker cabinets to deliver a rich, extended soundstage. And to ensure the highest quality standards, Ella is handmade in small quantities by expert craftsmen.
Built-in Audiophile Amp
Ella is the first headphone to offer planar magnetic sound quality with the convenience of a built-in 250mW audiophile amp. The amp pairs beautifully with Blue's custom matched drivers to deliver unprecedented headroom and clarity on your phone, laptop or tablet. Plus, Ella lets you personalize your listening experience with three all-analog amp modes—including one that restores the low-end character to vinyl-era music.
Key Features:
  • Planar magnetic technology for uncompromising clarity and detail
  • Built-in audiophile amplifier for true high-fidelity sound
  • Custom double-sided 50mm x 50mm drivers deliver incredible sound
  • Revolutionary personalized fit for superior comfort
  • Closed-back design for truest sound reproduction
  • Racecar-inspired multi-jointed headband design keeps earcups parallel at all times for superior comfort and sound
  • Powers on and off automatically when headphones are opened and closed
  • Rechargeable battery provides up to 12 hours of playtime; Ella continues to play music even when battery has no charge
Specs
Driver
Type Planar magnetic
Impedance 50 ohms Passive, 10 ohms Active
Frequency response 20Hz-20kHz
Enclosure details Sealed enclosure with tuned damping materials
Amplifier
Output power 250mW
THD+N < 1% (94 dB SPL, from 20 Hz to 20 kHz)
SNR >101 dB
Noise < 20 uV
Battery capacity 1000mAh
Headphone
Weight 481 g (16.97 oz)
Outer dimensions (closed) 21cm x 14cm x 12cm; 8.27” x 5.51” x 4.72
Outer dimensions (open) 18cm x 29cm x 12cm; 7.09” x 11.42” x 4.72”
In The Box
Blue Ella Planar Magnetic Headphones with Built-In Amplifier
Soft Case
3.9' Cable with iOS Controls & Mic
9.8' Audio Cable
3.5mm to 1/4" Adapter
Limited 2-Year Warranty
Subscribe
10% off Your First Order!
