The first of its kind, the Cayin N6ii is the most modular high-end DAP to hit the market. With the ability to remove and replace the Amp and DAC, the N6ii is customizable and full of possibilities.
- User Replaceable Audio Motherboard consists of DAC and analogue amplification circuit
- Direct Transport Audio (DTA) bypassing Android SRC, resampling free playback from all applications
- Fully Customized Android 8.1 with Google Play pre-installed, support popular streaming service such as Tidal and Spotify,
- Remote control by your mobile phone through HiByLink
- Comprehensive digital output option: I2S (mini HDMI), USB Audio, and S/PDIF
- Dual Band WiFi, Bluetooth 4.2 with Hi-Res Codec (aptX and LDAC) upto 96kHz
- Audio Motherboard A01
- DAC with AK4497EQ, the new generation premium 32-bit DAC based DAC chipset
- Native decode DSD up to 11.2MHz (DSD256), PCM up to 32bit/384kHz
- Fully balanced design with parallel headphone amplification, deliver hefty power to 3.5mm and 4.4mm phone out
- User adjustable 4.4mm and 3.5mm line out output level
UNLIMITED POSSIBILITIES
User Replaceable Audio Motherboard consists of DAC and analogue amplification circuit.
Every Audio Motherboard is a fully optimized solution from the ground up.
Change the audio circuit completely when a new Audio Motherboard is installed.
FUNCTIONAL DESIGN OF AUDIO MOTHERBOARD A01
Highly resemble the award winning design of ouyr flagship N8 DAP
One of the highest circuit density implementation among Cayin portable products
ANALOGUE CONNECTIONS FOR EVERY NEEDS
SINGLE-ENDED OR BALANCED? 4.4MM OR 2.5MM? WHY NOT BOTH?
Fully optimized 3.5mm and 4.4mm headphone output in amazing Cayin house sound.
High quality desktop grade 3.5mm analogue source for portable and desktop amplifier. Shared balanced line out to fill the niche usage.
Provided a custom designed 4.4mm to 2.5mm balanced adaptor for 2.5mm phone and line out.
COMPREHENSIVE CHOICES OF DIGITAL INTERFACES
High quality digital transport to work with wide range of desktop/portable digital audio devices.
Functioning as a Hi-Res DAC for your computer. Supports DSD output, DoP or D2P
A SMART PLAYER WITH AN OREO TREAT
Snapdragon CPU with 4GB RAM: Snappy operation with processing power to spare.
Customized Android 8.1 with Google Play: Choice of music and streaming app to explore music in style.
Cayin Music App and HiBy Music App preinstalled.
EXPAND WITH YOUR MUSIC LIBRARY
64GB Internal Storage: keep a hundred CD albums with you anytime, anywhere
One expansion slot accepts any SDXC format TF card (512GB tested), a portable music library with over 10,000 songs.
Almost unlimited OTG storage capacity: SD card, Flash Drive, SSD, HDD (external power supply)
DUAL BAND 2.4G/5G WI-FI
Widen your music horizon to a borderless realm.
POWERFUL AND LONG DURATION
YOU CAN HAVE YOUR CAKE AND EAT IT.
5900mAH 3.7V Battery and a carefully tuned Power Management System provides:
- 14hrs continuous playback upto 245mWPC (3.5mm Phone)
- 13hrs continuous playback upto 530mWPC (4.4 mm Phone)
- Quick Charge 3.0: Charges n6ii from 10% to 90% in 110 min
TRUE COLOR TOUCH SCREEN 4.2" 768X1280 IPS
Intuitive control through multi-point capacitive touch screen.
Dedicated Volume knob with playback buttons for different scenarios.
Detailed and natural graphic with wide viewing angle.
Highly readable text to enhance content browsing.
CLASSIC AND UNCONVENTIONAL
A FAMILY LOOK AND FEEL FROM "CAYIN DESIGN"
CNC machined aerospace aluminum alloy
High precision for perfect fit and installation
Finest sandblast finishing for sensational touch and grasp
DIMENSIONS
Size: 121mm x 70mm x 21mm
Weight: ~290g
