Close Cart
Your cart is currently empty.
Browse:
FiiO FH5 FiiO FH5
  • FiiO FH5
  • FiiO FH5
  • FiiO FH5
  • FiiO FH5
  • FiiO FH5
  • FiiO FH5
FiiO FH5
FiiO FH5
$259.99
  • Design Inspired by Exotic Supercars
  • S.TURBO Technology
  • Independent Sound Tubes
  • 3 x Knowles Balanced-Armature Drivers
  • 1 x 10mm Dynamic Driver for Bass
  • MMCX Connectors
  • 3.5mm Single-Ended Cable
  • Includes 4 Sets of Eartips
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The FH5 Quad-Driver Hybrid In-Ear Monitors from FiiO feature an acoustic design inspired by exotic supercars, S.TURBO technology, independent sound tubes, and three Knowles balanced-armature drivers for the high and mid frequencies and a 10mm dymanic driver for the bass. They are specifically designed to conform to the human ear and provide a snug, comfortable fit that allows you to focus on listening to music on your smartphone, MP3 player, and more.
    Exotic-Inspired Acoustics Design
    • The FH5's TRISHELL structural design features a 5-axis CNC machined aluminum-magnesium alloy rear shell, body, and front covers fixed tightly together with multiple screws— greatly reducing excess resonance and distortion.
    S.TURBO Technology
    • With its turbine-inspired design that makes clever use of the physics of sound waves, you get meaty, deep bass that is more than capable of letting you feel the music. S.TURBO also filters out unnecessary mid and high frequencies produced by the bass driver ensuring a more seamless transition between the lows and highs.
    • These tubes have been designed to integrate with the 4 driver units, allowing for a smooth transition between the three main regions of sound frequencies and maximizing the drivers' combined potential.
    Knowles Balanced-Armature + Dynamic Drivers
    • The FH5 employs a hybrid driver design that combines the best of balanced-armature and dynamic drivers for a balanced sound. Low frequencies are deftly handled by a 10mm polymer nanocomposite dynamic driver, providing bass extension. Mid frequencies are produced by the Knowles ED30262 balanced armature driver, while high and ultra-high frequencies are created by the Knowles 31082 driver.
    MMXC Connectors
    • The FH5's connectors on the cable make it easy to connect to other devices—with its elbow plug it can easily be changed. The grippy MMCX connectors are colored blue and red for identification.
    Copper Wire
    • The high-purity monocrystalline silver-plated copper wire that makes up the FH5's hybrid cable effective minimizes distortion and signal transmission loss for high-quality. These wires are braided together in an environmentally-friendly, transparent TPU sheath.
    Machined-Aluminum Alloy Shell
    • The shell of the FH5 is of aluminum alloy precisely machined with CNC technology, ensuring that it will continue to luster for years to come.
    • MMCX Connectors
  • In The Box
    • FiiO FH5 Quad-Driver Hybrid In-Ear Monitors
    • 6N Monocrystalline Silver-Plated Copper Cable with 3.5mm Right-Angled Plug
    • 4 x Sets of Eartips (Balanced, Vocal, Memory Foam, Bass)
    • Headphone Case
    • Storage Bag
    • Cleaning Brush
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
S.TURBO Technology
MMXC Connectors
Copper Wire
  • MMCX Connectors
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
