Close Cart
Your cart is currently empty.
Browse:
FiiO Q5 Bluetooth and DSD-Capable DAC and Headphone Amplifier FiiO Q5 Bluetooth and DSD-Capable DAC and Headp...
  • FiiO Q5 Bluetooth and DSD-Capable DAC and Headphone Amplifier
$349.99
  • Dual AK4490EN Chips
  • Audiophile-Grade Components
  • Audio up to 384 kHz / 32-Bit
  • High-Performance Bluetooth Audio
  • Native DSD Support
  • Interchangeable Amp Module
  • Balanced & Unbalanced Headphone Outputs
  • Coaxial, Optical, Line Inputs
  • High-Capacity 3800 mAh Battery
  • MFi-Certified for Apple iOS Devices
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The FiiO Q5 is a portable Bluetooth and DSD-capable DAC and headphone amplifier that delivers high-fidelity sound on the go. It packs a multitude of features in a compact and lightweight (at 6.87 oz) frame, and offers both wired and wireless connections for use with most audio sources such as smartphones, tablets, and computers.
    The Q5 employs audiophile-grade components including dual AK4490EN DAC chips for audio up to 384 kHz / 32-bit and an XMOS XU208 micro-controller chip to ensure connection stability and reliability when connected to most audio sources. A specially designed power supply provides each of the unit's major components with its own filtered and regulated power, resulting in a clean and natural sound, free from component interference.
    The interchangeable amp module design allows you to customize your Q5 with the appropriate amp module, based on the power needs of your headphones or your preferred sound signature. The unit ships with an AM3A amp module, which provides 2.5mm TRRS balanced and 3.5mm TRS unbalanced headphone outputs. The Q5 offers a comprehensive set of inputs including line, coaxial, and optical. Two USB ports let you transmit digital audio signal on one port, while accessing ample power on the other to ensure optimal sound quality.
    The Q5 delivers high-performance Bluetooth audio by passing the Bluetooth signal directly to the AK4490EN DAC chips through the XMOS chip, for a lower noise floor and reduced total harmonic distortion and crosstalk. A 3800 mAh, high-capacity rechargeable battery combined with intelligent power management provides up to 10 hours of operation when the unit is used as a DAC or as a Bluetooth receiver.
    The carefully surfaced, CNC aluminum body and backside polyurethane leather finish give the Q5 its minimalist and sophisticated look. Controls are designed for simplicity and intuitiveness with a protruding volume wheel that is comfortable to use. Gain and bass boost controls allow you to switch between low and high gain depending on how much power is needed to efficiently drive your headphones, as well as emphasize the bass according to your preferences.
  • In The Box
    • AM3A Amp Module
    • Short Lightning to Micro-USB Cable
    • Long USB Type-A to Micro-USB cable
    • 3.5mm Stereo Mini to 3.5mm Stereo Mini Cable
    • Coaxial Adapter
    • Optical Adapter
    • 2 x Short Straps
    • 2 x Long Straps
    • Screwdriver
    • Non-Slip Mat
    • Carrying Pouch
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
