Close Cart
Your cart is currently empty.
Browse:
FiiO X5 (3rd Gen) FiiO X5 (3rd Gen)
  • FiiO X5 (3rd Gen)
  • FiiO X5 (3rd Gen)
FiiO X5 (3rd Gen)
FiiO X5 (3rd Gen)
$399.99
  • Audio Player & USB DAC
  • Supports up to 32-Bit / 384 kHz
  • Native DXD and DSD Playback
  • Plays PCM, WAV, FLAC, AAC, MP3, & More
  • 3.97" 800 x 480 IPS Display
  • Dual microSD Card Slots
  • Line/Digital Coax & Dual Headphone Out
  • Dual AKM AK4490EN DAC Chips
loading
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The Fiio X5 (3rd Gen) is a portable high-resolution audio player and USB DAC for audio enthusiasts. The unit features an audiophile-grade architecture and premium components capable of playing files up to 32-bit/384 kHz in a variety of formats including native DSD, DXD, WAV, WMA, ALAC, FLAC, APE, AIFF, and more.
    The X5 utilizes a pair of AKM AK4490EN DAC chips coupled to two dual-channel OPA1642 LPF chips and an OPA426 amplification chip for improved dynamic performance. Dual crystal oscillators ensure the lowest jitter and highest precision playback of music at any sample rate, reducing conversion artifacts.
    The player offers a 3.5mm single-ended headphone output and a separate 3.5mm line out/digital (coaxial) output. A 2.5mm balanced headphone output lets you use the headphones of your choice. The third-edition X5 has 32GB of onboard memory, which can be augmented with two microSDXC card slots. The 3400mAh lithium-ion polymer battery provides up to 10 hours of playback under normal conditions. The Android-based user interface offers five unique themes, while the 2.4" IPS color touchscreen display offers easy navigation. The 10-band graphic EQ and the 120-step digital volume control allow for custom-tailored sound and levels.
    The X5-III body is made from No. 180 zirconium sand with stainless steel accents, with a dot matrix pattern on the front and a star pattern on the back. The player ships with a USB cable, coaxial digital adapter cable, a clean case, a leatherette case, and a pre-applied tempered glass screen protector.
    Dual DACs
    The X5 3rd gen has one 32-bit AKM AK4490EN DAC per channel, each of which supports all PCM and DSD formats. AKM’s VELVET SOUND low-distortion architecture includes digital filtering with 32-bit processing for accurate sound reproduction.
    Dual Crystal Oscillators
    Two crystal oscillators, one for DSD/44.1/88.2/176.4/352.8 kHz sampling rates and the other for 48/96/192/384 kHz sampling rates, for reduced jitter and sampling rate conversion artifacts and improved clock accuracy.
    Four-Way Low Pass Filtering
    Two dual-channel OPA1642 low-pass filtering chips and dual custom OPA426 amplification chips combine to provide up to 300mW under a 32-Ohm load and improved capacitive load ability.
    Dual Headphone Jacks
    Along with a 3.5mm line-out/coaxial-out jack, the third-generation X5 has a standard single-ended 3.5mm headphone jack and a 2.5mm balanced TRRS headphone jack.
    Wireless Connectivity
    The third-gen X5 has 2.4 GHz 802.11 b/g/n Wi-Fi for connecting to wireless LANs and Bluetooth 4.0 with aptX and DLNA for connecting to other devices.
    USB DAC
    The micro-USB port enables use as a USB DAC for your computer or as a transport, outputting digital signals to an external DAC.
    Android 5.1 Lollipop and Pure Music Mode
    The X5’s version of Android 5.1 has been customized by FiiO with a new audio software architecture to prevent third-party Android apps from automatically converting sample rates.
    The player can also be switched into Pure Music Mode, which switches off all apps other than the main music player for smooth operation and improved sound.
    Volume Knob
    The physical volume knob is recessed slightly to avoid changes in your pocket and has 45° grooves for quickly moving through 120 steps of volume control.
    Battery and Charging
    The 3.8V 3400mAh battery lasts for approximately 10 hours when using the 3.5mm headphone jack and approximately 8 hours when using the 2.5mm jack. It can be charged at the standard BC 1.2 USB rate but also at 9 or 12 V rapid charging at a rate of up to 1.2A for a complete fill in as little as two hours.
  • Tech Specs
    General
    Operating System
    Android 5.1.1 Lollipop
    Chipset
    ARM Cortex A9
    CPU
    Rockship RK3188
    Number of Cores
    4
    Clock Speed
    1.4 GHz
    RAM
    1 GB
    Storage
    32 GB (approximately 26 GB available to user)
    Storage Expansion
    2 x microSDXC
    DAC
    2 x AKM AK4490EN
    Oscillators
    1 x 22.5792 MHz (DSD / 44.1 / 88.2 / 176.4 /352.8 kHz),
    1 x 22.576 MHz (48 / 96 / 192 / 384 kHz)
    Filtering
    Low Pass
    2 x dual-channel OPA1642 chips,
    Amplification
    2 x OPA246 chip
    Recommended Headphone Impedance
    16 to 150 Ohms
    DAC Outputs
    USB, up to 192 kHz/24-bit
    Software & Features
    Volume Control
    120 steps, knob-controlled
    Gain Control
    Low/high
    Equalizer
    10-band, ±6 dB, 9 presets + custom preset
    File Formats
    Lossless
    DSD: DSD64/128 (.iso, .dsf, .dff),
    DXD: 352.8K,
    APE FAST/High/Normal: 384 kHz/24-bit (max),
    APE Extra High: 192 kHz/24-bit (max),
    APE Insane: 48 kHz/24-bit (max),
    Apple Lossless: 384 kHz/24-bit (max),
    AIFF: 384 kHz/24-bit (max),
    FLAC: 384 kHz/24-bit (max),
    WAV: 384 kHz/32-bit (max),
    WMA Lossless: 96 kHz/24-bit (max)
    Lossy
    MP3
    AAC
    WMA
    OGG
    Wi-Fi
    802.11 b/g/n,
    2.4 GHz
    Bluetooth Version
    Connector 1
    Micro-USB 2.0
    Connector 2
    3.5mm line-out/coaxial out
    Connector 3
    3.5mm headphone out
    Connector 4
    Connector 5
    FiiO dock connector
    Display
    Type
    IPS TFT touchscreen
    Size
    3.97" (10.08 cm)
    Resolution
    800 x 480
    Pixel Density
    233 ppi
    Viewing Angle
    178°
    Colors
    16.7 million
    Line Output
    Frequency Response
    5 Hz to 55 kHz (-3 dB)
    THD+N
    <0.0009% (1 kHz/10 kOhms)
    Signal to Noise Ratio
    ≥120 dBA
    Dynamic Range
    >117 dB
    Line Level
    >1.8 Vrms
    Channel Separation
    >98 dB (1 kHz)
    Headphone Output
    Output Power
    3.5mm
    Level 1: ≥480 mW (16 Ohms,THD+N <1%),
    Level 2: ≥250 mW (32 Ohms,THD+N <1%),
    Level 3:≥28 mW (300 Ohms,THD+N <1%)
    2.5mm TRRS (balanced)
    Level 1: ≥400 mW (16 Ohms,THD+N <1%),
    Level 2: ≥240 mW (32 Ohms,THD+N <1%),
    Level 3:≥26 mW (300 Ohms,THD+N <1%)
    Frequency Response
    3.5mm
    THD + N
    3.5mm
    <0.003% (1 kHz)
    <0.003% (1 kHz)
    3.5mm
    ≥115 dBA
    ≥111 dBA
    Channel Separation
    3.5mm
    >73 dB (1 kHz)
    ≥98 dB (1 kHz)
    Output Impedance
    3.5mm
    <1 ohm(32 Ohms loaded)
    <3 ohm(32 Ohms loaded)
    Peak Output Voltage
    3.5mm
    >8 Vp-p
    >7.5 Vp-p
    Max Output Current
    3.5mm
    250 mA (for reference)
    Power
    USB Power
    12 VDC/1.5 A
    9 VDC/2 A
    5 VDC/2 A (recommended)
    Battery Type
    Lithium-ion polymer (LiPo)
    Battery Capacity
    3400 mAh
    Battery Life
    3.5mm Output
    Up to 10 hours (27 Ohms M3 open earbuds, volume level 48, 44.1 kHz/16-bit MP3 file, high gain, screen off, EQ off)
    2.5mm Output
    Up to 8 hours (32 Ohms, volume level 48, 44.1 kHz/16-bit MP3 file, high gain, screen off, EQ off)
    Battery Charge Time
    12 VDC/1.5 A: Approximately 2 hours
    5 VDC/2 A: Approximately 3 hours
  • In The Box
    • FiiO X5 (3rd Gen) Portable High-Resolution Audio Player
    • USB Cable
    • Coaxial Digital Adapter Cable
    • Clean Case
    • Leatherette Case
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    Based on 2 reviews
    100%
    (2)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    t
    t.o.
    Great player
    The player got here in 2 days I was shocked at how fast it got here kudos headphones.com as far as the player it's wonderful great sound and lots of features and can handle almost any headphones I pair them with my sennheiser hd650 and k5 desktop amp great player love it
    z
    z.
    Awesome Player !!
    I upgraded from the Fiio X5 second generation to the Fiio x7. I had many issues with the x7 second generation so I sent that back and bought the Fiio x5 3rd generation even after reading negative reviews. I have had no issues at all with mine. Updated it once when I received it and it has worked great. Sound is awesome and everything works smoothly. Not a single issue so far after about a month of use. Great audio player.
Dual DACs
USB DAC
Volume Knob
Customer Reviews
Based on 2 reviews
100%
(2)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
t
t.o.
Great player
z
z.
Awesome Player !!
