Close Cart
Your cart is currently empty.
Browse:
Final Audio F7200 Final Audio F7200
  • Final Audio F7200
Final Audio F7200
Final Audio F7200
$479.00
  • Stunning detail and clarity
  • Reference-level headphones
  • Small design for a deep, snug fit
  • MMXC connector makes cable replacement easy
  • High-Quality silver sheathed cable included
Headphones.com is stoked to be accepting NANO, Bitcoin, Ethereum, Litecoin and many more cryptocurrencies!
  • Description
    The F7200 from Final Audio is a very strong showing among in-ear headphones for Final Audio.
    Featuring a single balanced armature driver in stainless steel housing, the F7200 is pretty close to a reference-level headphone delivering stunning clarity and detail. The F7200 in-ear headphones let you pick out minute details in your high-resolution audio that you may not have heard before. The F7200 is an absolute beast when it comes to mids and highs although bassheads beware, these are probably not the headphones you are looking for. The F7200 comes with a silver sheathed cable with MMXC connectors meaning that it is replaceable although the stock cable the F7200 comes with is fantastic and definitely worth holding on to! As with the other headphones in Final Audio's F series, the F7200 has an impedance of 42 ohms which means we wouldn't recommend trying to drive them straight from your phone.
    *Headphones.com is very pleased to announce that you have even more options to pay for your Final Audio F7200 headphones! Now when you hit the Pay with Cryptocurrencies button, you have the option to pay with cryptocurrencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
  • Tech Specs
    Housing
    Stainless Steel
    Driver Unit
    Balanced Armature driver
    S.P.L.
    106dB
    Impedance
    42 Ohm
    Length Of Cable
    1.2m
    Weight
    23g
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
