Focal Clear Professional Headphones Focal
Regular price $1,699.00
5 in stock
Free Shipping
365 Day Returns
No Tax
The Clear Professional Headphones from Focal represent the essential tool for the most demanding professionals. The only objective: to be the ultimate tool for high quality playback. These open-back, over-ear headphones incorporate a remarkable evolution of the driver and an extremely open design aiming to make the headphones disappear, for the benefit of the sound. Clear Professional headphones are so comfortable that you forget you are wearing them and the listening experience feels like studio monitors.
Its M-profile Aluminum/Magnesium dome has a new copper coil which provides total dynamic respect over the entire audio spectrum, with an extremely well defined and always controlled bass. At the same time, the very low-mass speaker moving parts mean that these headphones reproduce the finest details in the higher frequencies. Turning to the headband and yokes, their design ensures that the headphones are in full contact with the head, for optimal comfort. The new generation of perforated microfiber ear cushions provides an extremely open design.
Unveiled secrets
The Clear Professional from Focal uses a new generation of Focal 40 mm full-range speaker. A 25mm diameter, 5.5mm long unsupported copper coil has been developed. The material chosen, copper, has the effect of achieving an extremely high magnetic field in the coil. With this, the moving parts are always under control, even at maximum capacity, providing bass definition worthy of the best subwoofer's. Its 55Ohms impedance makes Clear Professional easy to drive, even in a mobile configuration, directly connected to the headphones output of a laptop.
It contributes to an exceptional impulse response with a break-up raised to 24kHz. Thus, high frequencies are extremely linear and transients totally respected. Clear Professional is capable of precisely revealing the finest details of the recording, proving extremely precise control.
35 Years' Know-how
What makes headphones significantly different from a pair of monitor speakers is the wave-form generated by the loudspeaker and the listening distance. In order to achieve a plane wave in a very close nearfield, the shaping of the dome had to be rethought carefully because of the few centimeters of distance inside it.
M-profiled Dome
The Focal's 35 years of experience have resulted in a new generation of domes, launched on Elear and Utopia headphones: the M-profile dome. Formed from an Aluminum/Magnesium alloy, it offers an ideal ratio, combining low mass, high rigidity and excellent damping. The depth of the sound and the dynamics won't disappoint you.
Truly Excellent Design
The design of Clear Professional solves the sensation of space reduction, thanks to their new microfiber ear cushions. Their one-millimeter diameter micro-perforations on the outside edge give a level of openness that is unbeatable at this price range. The listening experience in the room, rather than headphones, is intensified. The second benefit to this design is its extreme tolerance to ear cushion positioning, regardless of head profile and size. This degree of openness also provides the benefit of excellent definition of upper bass and low mid-range registers, typically where headphones usually struggle in comparison with monitors.
*Headphones.com is very pleased to announce that you have even more options to pay for your Focal Clear Professional headphones! Now when you hit the Pay with Crypto button, you have the option to pay with cryptocurrencies like NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
Type
Over-Ear open-back headphones
Driver
1.6" (40mm) Aluminum/Magnesium
Impedance
55 Ohms
Sensitivity
104dB SPL / 1mW at 1kHz
THD
0.25% at 1kHz / 100dB SPL
Frequency Response
5Hz - 28kHz
'M'-shape dome
Connectors
Headphones
1/8" (3.5 mm) jack sockets with locking mechanism
Cable 1
1/4" TRS
Cable 2
1/8" (3.5 mm) TRS
Cable Length
16.5' (5.03m) Unbalanced Coiled Cable
3.9' (1.19m) Unbalanced Cable
  • Focal Clear Professional Open-Back Studio Monitor Headphones
  • 16.5' Unbalanced Coiled Cable with 1/4" TRS Jack
  • 3.9' Unbalanced Cable with 3.5mm TRS Jack
  • 3.5mm to 6.35mm Jack Adapter
  • 2x Spare Cushions
  • Rigid Carry Case
  • Focal 1 Year Limited Warranty
