Focal Sphear High-Resolution In-Ear Headphones - headphones.com
Color
Silver
Intended to reproduce music exactly as it's been performed, recorded, and mixed, the Focal Sphear High-Resolution In-Ear Headphones are crafted to deliver an extended frequency response in the low end and an overall tonal balance: 10.8 mm electro-dynamic multi-channel transducers and Focal's Bass Reflex system help reproduce punchy lows, while Mylar drivers and a ported built-in acoustic chamber help ensure neutrality in the mid and upper ranges. These headphones can get quite loud as well, delivering a sound pressure level of up to 103 dB.
However, tone and volume aren't the only considerations; comfort has been taken into account as well: The earbuds themselves are encircled by a stainless-steel ring and grille that, in addition to the extended housing of the back frame, pivots the weight of the unit toward the inferior auricle of the ear, rather than the twistier parts of the exposed canal. These features, in conjunction with adaptable memory-foam tips, are designed to provide a comfortable listening experience—even for hours at a time.
These headphones also come standard with a multi-functional remote (enabling control over Android, Apple, and Windows smartphones, tablets, and other devices), and an on-board omnidirectional microphone that helps provide clarion tone for phone calls and smartphone commands.
Included with the unit are a carrying case and an aircraft adapter to ensure in-flight enjoyment.
  • 10.8mm drivers and Focal's Bass Reflex system for optimal in-ear bass experience
  • Mylar drivers and built-in ported acoustic chambers for accurate mid-range and highs
  • Capable of delivering 103 dB of SPL
Comfort
  • Stainless-steel ring and grille construction and extended rear-housing for better ear-canal placement
  • Memory-foam tips adapt to the specific contours of your ear
  • Included silicone tips can be utilized as well at your discretion
Remote Control and Microphone
  • Multi-function remote for controlling smartphones, tablets, computers, and more
  • Single button on cord controls music track play/pause/advance and accept/end phone call
  • On-board omnidirectional microphone
Type Closed-Back Intra-Aural
Frequency Range 20 Hz to 20 kHz
Impedance 16 ohms
Sensitivity 103 dB
THD & Noise < 0.3%
Frequency Response 20 Hz to 20 kHz
Driver 10.8 mm Mylar Electro-Dynamic
Microphone Omnidirectional
Weight 0.03 lb / 15 g
Packaging Information
Package Weight 0.35 lb
Box Dimensions (LxWxH) 7.2 x 3.1 x 2.4"
3 x Memory Foam Tips (Small, Medium, Large)
3 x Silicone Tips (Small, Medium, Large)
Aircraft Adapter
Carrying Case
Limited 2-Year Warranty
Subscribe
10% off Your First Order!
