Fostex HP-A8C 32-Bit DAC and Headphone Amplifier - headphones.com
Color
Black
  • The Fostex HP-A8C 32-Bit DAC Headphone Amplifier is a high-fidelity digital-to-analog converter with a discrete analog headphone amplifier. With this DAC, you can listen to music on headphones or speakers from a computer over USB or from another audio source device. For inputs, the DAC accepts digital AES/EBU, digital optical, digital coaxial, SD cards via an SDHC card slot, or analog RCA. For audio streamed via USB, coaxial and optical inputs, the DAC can up sample the incoming signal by x2 or x4 at up to a 192 kHz sample rate with 32-bit resolution for Mac OS X and 24-bit resolution for Windows.
    Outputs
    • For outputs, the DAC features RCA line and two 1/4" headphone jacks
    Control
    • A button on the front of the unit allows you to turn the power off/on, and two knobs allow you to select the input and output sources. An electronic volume knob allows you to adjust the headphone gain from 0 to -12 dB in 0.5 dB step increments. A direct-out mode can be engaged to bypass the volume control knob altogether. For added convenience, the DAC comes with a dedicated remote controller
    Built-in SDHC Card Slot for DSD Playback
    • The SD card slot can playback content in Direct Stream Digital File format (DSF)
    Asynchronous Mode with TCXO Clock
    • To keep precise low-jitter time, the DAC utilizes an internal asynchronous temperature-compensated crystal oscillator clock
    Power
    • The DAC utilizes a large-capacity toroidal transformer power supply
    Selectable Internal or External Clock
    • The DAC can utilize either its internal asynchronous crystal oscillator clock or be switched to sync via digital I/O to an external clock source such as from a separate analog to digital converter, a master clock, or a reference clock for syncing audio to video
    Digital Filter Selection
    • To remove pre-echo from playback, the DAC allows you to select between a traditional sharp roll off and a minimum delay filter
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
Free Headphone Stand With Your First Order
