Fostex TE-07 In-Ear Headphones - headphones.com
No reviews
Color
Bronze
  • The Fostex TE-07 In-Ear Headphonesuses a single balanced armature driver system within a machined aluminum housing to provide a clear and articulate frequency response of 20 to 20,000 Hz into a 33 ohm load with a sensitivity of 95 dB (at 1 kHz, 1 mW). The 3.9' (1.2m) cable is detachable for easy replacement, and will also work as an upgrade for the Fostex TE-05 Inner ear headphones. The right unit of connector has a small projection in red for easy identification. The headphones come with four sizes of ear tips (XS, S, M, L) to ensure a comfortable fit as well as a leather carrying case with an embossed Fostex logo.
Subscribe
10% off Your First Order!
