Close Cart
Your cart is currently empty.
Browse:
iFi Audio micro iUSB3.0 Power Conditioner iFi Audio micro iUSB3.0 Power Conditioner
  • iFi Audio micro iUSB3.0 Power Conditioner
$429.00
  • Enhances USB Audio
  • 0.1µV Noise Floor
  • Active Noise Cancellation+
  • 5.0 Gbps Transfer Rate
  • Four USB 3.0 Ports
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    Improve your audio with the iFi Audio micro iUSB3.0 Power Conditioner. This conditioner is designed to reduce loss of detail, pops, hisses, hums, and other artifacts by correcting signal balance, suppressing frame, packet, and ground noise, cleaning power, correcting impedance mismatch, restoring signal integrity, and eliminating USB jitter. It offers a 0.1µV noise floor, ANC+, and 5.0 Gbps transfer rates via a pair of USB 3.0 ports. Two more USB 3.0 ports provide power only.
    • iFi's Active Noise Cancellation+ generates a mirror image of the noise signal, actively canceling it out for a noise floor of 0.1µV.
    REclock & REgenerate
    • The micro iUSB3.0 reclocks, regenerates, and repeats the USB audio datastream. REgenerate creates a new USB signal for downstream DACs and employs the REclock master clock to minimize computer jitter.
    REbalance
    • REbalance removes DC offset and rebalances the USB signal.
    IsoGround
    • IsoGround removes the noise caused by your computer's ground connection without breaking it, in order to stay compliant with USB standards. The Auto/On USB power line option gives you more control over your power.
    Dual-Ports
    • Two sets of Dual-Ports let you connect two devices, such as a DAC and hard drive, without the noise from one source contaminating the other. The ports are also Bus Charge 1.2 compliant and can recharge devices at up to 2.5 A.
    • 0.1µV Noise Floor
  • Tech Specs
    Output Voltage
    5 V ±0.5%
    Output Current
    2.5 A total
    Noise Floor
    0.1 µV
    USB Transfer Rates Supported
    Up to 5.0 Gbps
    Connectors
    1 x 9 VDC power in
    1 x USB Type-B input
    2 x USB 3.0 Type-A output (power only)
    2 x USB 3.0 Type-A output (power and audio)
    Input Voltage
    100 to 240 VAC, 50/60 Hz
    Power Consumption
    <15 W (includes powered USB device)
    Dimensions
    6.2 x 2.7 x 1.1" (15.8 x 6.8 x 2.8 cm)
    Weight
    10.1 oz (285.0 g)
    Package Weight
    1.55 lb
    Box Dimensions (LxWxH)
    8.1 x 3.6 x 3.3"
  • In The Box
    • iFi AUDIO micro iUSB3.0 Power Conditioner
    • Power Supply
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
REbalance
IsoGround
Dual-Ports
  • 0.1µV Noise Floor
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
