Klipsch Reference On-Ear Closed-Back Bluetooth Wireless Headphones - headphones.com
Color
White
Black
  • The Klipsch Reference On-Ear Bluetooth Headphones have been designed with Bluetooth wireless capabilities, so that you may stream audio and phone calls in a manner becoming the Reference On-Ear series. As with previous models, these headphones provide a minimal, clean aesthetic and clear, crisp, and accurate sound. They give you 40mm dynamic moving-coil drivers which deliver a frequency response of 20 Hz to 20 kHz. With deep and soft ear cushions, these headphones offer both a comfortable listening experience and passive noise-isolation. Furthermore, they can fold up when not in use, so you can store them in the included carry case when you're traveling.
    The difference lies in their wireless abilities: Over Bluetooth 4.0, these headphones stream high-definition aptX and AAC streaming, ensuring fidelity in your sonic experience. A built-in mic and remote give you controls, as well as the ability to converse with people over your phone. You can use these headphones up to 10m away from your Bluetooth source, and the integrated battery will give you a running time of up to 20 hours at a clip. You can recharge the battery with a micro-USB cable, included with the headphones. Also included are a pass-through cable for passive listening and a travel case.
    Key Features
    • Clear, articulate sound
    • Bluetooth 4.0 with aptX and AAC
    • Range of up to 10m
    • iOS battery-status monitor
    • Integrated microphone and controls
    • Included pass-through cable, micro-USB cable, and travel case
Subscribe
10% off Your First Order!
