Klipsch Reference Over-Ear Closed-Back Bluetooth Wireless Headphones - headphones.com
Color
Black
White
  • The Klipsch Reference Over-Ear Bluetooth Headphones have been designed with Bluetooth wireless capabilities, so that you may stream audio and phone calls in a manner becoming the Reference Over-Ear series. They provide a 40mm dynamic moving-coil driver which delivers a frequency response of 15 Hz to 20 kHz. With removable memory-foam cushions that are deep and soft, these over-ear headphones offer both a comfortable listening experience, as well as an accurate one; patented Klipsch Balanced Dynamic driver technology equalizes the weight of the unit's diaphragm, eliminates the need for lead wires, and aims to reduce intermodulation distortion. All of this contributes the articulation and clarity of the sound.
    Over Bluetooth 4.0, these headphones stream high-definition aptX and AAC streaming, ensuring fidelity in your sonic experience. A built-in mic and remote give you controls, as well as the ability to converse with people over your phone. You can use these headphones up to 10m away from your Bluetooth source, and the integrated battery will give you a running time of up to 20 hours at a clip. You can recharge the battery with a micro-USB cable, included with the headphones. Also included are a pass-through cable for passive listening and a travel case.
    Key Features
    • Clear, articulate sound
    • Bluetooth 4.0 with aptX and AAC
    • Range of up to 10m
    • iOS battery-status monitor
    • Integrated microphone and controls
    • Included pass-through cable for passive listening
    • Included micro-USB cable and travel case
Subscribe
10% off Your First Order!
