Klipsch X12 Neckband Bluetooth Wireless In-Ear Headphones - headphones.com
Color
Black
Brown
  • The Klipsch X12 Neckband Bluetooth features KG-926 balanced-armature drivers which deliver a wide frequency response of 5 Hz to 19 kHz. Placed inside a milled aluminum housing, the drivers utilize a ported and vented construction to deliver an experience suitable for audiophiles, recreating a vintage tube-amplifier sound with natural lows. The headphones have been crafted with copper accents and stitched leather to further emphasize the feeling of quality.
    These in-ear headphones sport a sound commensurate with the X12 line, so if you're a fan of those, you'll definitely enjoy the Bluetooth version, which provides aptX and AAC technology for high-quality audio streaming. Its built-in rechargeable battery can last up to 18 hours on a single charge, while its three-button remote and clear-voice microphone allow you to seamlessly control your Android or Apple device. The microphone also actively reduces environmental noise so that your voice may ring loud and clear. The eartips included with the X12 Neckband Bluetooth feature a patented contour design to promote comfort, and the headphones include Comply Ts-100 comfort tips for a personalized experience.
    Vibration Notification
    With a vibration-alert system built into the left control pod, you can stop worrying about missing important calls if your phone is out of reach. The Neckband will vibrate against your collar bone to notify you of an incoming call. Pick the call up directly from the right control pod and take your call using the built-in cVc microphone.
    Klipsch Sound
    Utilizing custom KG-926 balanced armatures placed inside of a milled aluminum housing, the X12 Neckband achieves full-range response from a tiny form factor. Ported and vented, the balanced-armature driver aims to deliver tube-amplifier sound and a natural bass performance, providing a warm and lush soundstage.
    Patented and Comfortable Design
    These earphones utilize patented contour eartips that are anatomically designed to accurately sit inside the ear canal. These soft oval silicon tips aim to reduce ear fatigue as well as provide a seal for passive noise isolation and bass response.
    Three-Button Remote and Clear Voice Mic
    The remote/microphone combination offers full control of most smartphone models including Android and Apple devices, allowing for seamless control of music and phone calls. Equipped with cVc technology, these in-ear headphones automatically enhance voice clarity and actively reduce environmental noise to ensure you sound loud and clear.
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
Free Headphone Stand With Your First Order
