Klipsch X12i In-Ear Headphones
Color
Black
  • The X12i In-Ear Headphones from Klipsch are designed for playing back music as well as taking calls from your iOS or mobile device. The headphones feature a milled aluminum chassis less than 6mm in diameter, with balanced armature drivers designed for accurate sound reproduction, and a thick copper cable for high efficiency and lower noise. The X12is have an in-line directional mic and 3-button remote that is optimized to work with compatible iOS devices. Klipsch includes 5 pairs of their oval eartips to assure a comfortable fit while providing up to 26 dB of noise isolation.
    Thin, Lightweight, and Durable
    With a milled aluminum chassis less than 6mm in diameter, the X12i is one of the smallest headphones on the planet. Aided by the use of aluminum, not only is the X12i incredibly durable, but it also becomes unnoticeable during wear due to its diminutive weight
    Audiophile Balanced Armature
    Utilizing a single custom KG-926 balanced armature, X12i achieves full range response from a tiny form factor. Ported and vented, the balanced armature driver delivers classic tube amplifier sound and unmatched bass performance. With a warm and lush soundstage, the KG-926 delivers dynamics only rivaled by multi-armature counterparts
    Patented Oval Ear Tips
    Soft, flexible oval ear tips naturally fit the contours of the ear canal for comfortable, long-term wear and create a perfect acoustic seal for superior noise isolation
    Advanced 3-Button Mic and Remote
    Offers seamless control of your iPhone, iPad, or iPod while listening to music, watching movies and answering phone calls
Subscribe
