Close Cart
Your cart is currently empty.
Browse:
Klipsch X20i Klipsch X20i
  • Klipsch X20i In-Ear Headphones - headphones.com
Klipsch X20i
Klipsch X20i
$549.00
  • Surgical-Grade Stainless Steel
  • High Resolution Super Tweeter
  • Interchangeable Cables
  • Advanced 3-Button Mic and Remote
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The X20i from Klipsch are audiophile in-ear headphones designed for playing back music as well as taking calls from your iOS or mobile device. The headphones feature an injection-molded stainless steel housing, with two-way, broad-band balanced armature drivers designed for accurate sound reproduction, and a thick copper cable for high efficiency and lower noise. The X20is have an in-line directional mic and 3-button remote that is optimized to work with compatible iOS devices. Klipsch includes 5 pairs of their oval eartips to assure a comfortable fit while providing up to 26 dB of noise isolation.
    Hear the Air
    X20i is the most revealing in-ear headphone Klipsch has ever made. High frequencies are reproduced with unheard-of accuracy and bass is clear, full, and warm. The X20i sets a new standard in headphone acoustics. Powered by a true two-way dual armature design, the high-horsepower KG-926T woofer is mated to a high resolution KG-125B super tweeter. This results in a palpable sound character and makes X20i the broadest bandwidth in-ear headphone available from Klipsch.
    The KG-125B super tweeter creates a truly transparent sound. With high-frequency performance created to take advantage of superb lossless recordings, this headphone delivers hi-hats and cymbals with lifelike realism.
    Injection-molded surgical-grade stainless steel is the primary material used in the X20i chassis. Complemented by a reverse hood scoop, X20i is one of the smallest and most durable two-way headphones on the market.
    Super-Slim Ear Tips
    With the introduction of X20i comes the most comfortable ear tip we have ever designed. Pre-installed on the product, we have redesigned our most popular ear tip into a super slim form factor. After extensive research, our surveys lead to the conclusion that ear canals are even narrower than we had ever expected. The super slim ear tip addresses that by using an even narrower and more tapered design, enabling people who have never found in-ear monitors to be comfortable to wear them without fatigue. However, all ears are unique, so included with the product are five additional sizes to choose from.
    Complementing the groundbreaking design and acoustics of X20i is the ability to swap cables. Screw-type coaxial SSMCX connectors for both left and right sides allow for swapping cables or using custom balanced cables. Approximately 35% smaller than industry-standard MMCX connectors, X20i has all the advantages of interchangeable cables without any of the bulk.
    Offers seamless control of your iPhone, iPad, or iPod while listening to music, watching movies and answering phone calls.
  • Tech Specs
    Type
    In-Ear
    Driver Design
    KG-2625 AcuPass(R) Two-Way
    Drivers
    KG-125B: Balanced armature super tweeter
    KG-926T: Balanced armature woofer
    Mic/Remote
    Mic + 3-button remote
    Frequency Response
    5 Hz to 40 kHz
    Sensitivity
    111 dB @ 1 mW
    Impedance
    50 Ohms (1 kHz)
    Noise Isolation
    -26 dB
    Input Connections
    1/8" / 3.5 mm
    Weight
    0.8 oz / 22.0 g
  • In The Box
    • 5 x Pairs of Eartips
    • Tie Bar
    • Genuine Leather Carrying Case
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Hear the Air
Super-Slim Ear Tips
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
