Close Cart
Your cart is currently empty.
Browse:
Klipsch XR8i Klipsch XR8i
  • Klipsch XR8i Hybrid In-Ear Headphones - headphones.com
Klipsch XR8i
Klipsch XR8i
$279.00
  • High-clarity balanced armature
  • Bass-tuned dynamic subwoofer
  • Die-Cast Zinc and Co-Molded Elastomer Housing
  • Patented Oval Ear Tips
  • Advanced 3-Button Mic and Remote
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The XR8i Hybrid from Klipsch are audiophile quality in-ear headphones designed for playing back music as well as taking calls from your iOS or mobile device. The headphones combine KG-723 balanced armature driver with a 6.5mm dual magnet dynamic sub-woofer driver to deliver accurate and high energy sound without distortion. The XR8i feature a highly durable and high-quality enclosure that uses physical vapor deposition to create a gunmetal finish. The in-line directional mic and 3-button remote is optimized to work with compatible iOS devices. Klipsch includes 5 pairs of their oval ear-tips to assure a comfortable fit while providing up to 26 dB of noise isolation. The XR8i Hybrid also ships with a clothing clip, and a carrying case.
    Hybrid Design - Home Theater Sound
    Combining the thundering, rich bass of R6i’s custom 6.5mm dual magnet dynamic driver with the exceptional tonal balance and high-frequency definition of the KG-723 balanced armature, the Klipsch XR8i Hybrid In-Ear Headphones deliver sound only paralleled by a home theater.
    High Clarity Balanced Armature
    Klipsch’s custom, single full-range KG-723 balanced armature delivers cleaner, more natural sounding vocals and defined upper frequencies only achievable through balanced armature technology.
    Bass-Tuned Dynamic Subwoofer
    XR8i utilizes a 6.5mm dual magnet dynamic driver to reproduce low, sub-bass. With a moving coil driver focused on reproducing only low frequencies, the XR8i creates the headroom necessary to drive highly-dynamic recordings with high energy and without distortion.
    X6i’s minimal design combines sturdy die-cast zinc for the front housing, optimally weighted to stay put inside your ear canal. The high quality and durable rear housing is built from co-molded elastomer, a two-layer design with a rigid inner layer for support and a soft-touch pliable outer layer for comfort.
    Soft, flexible oval ear tips naturally fit the contours of the ear canal for comfortable, long-term wear and create a perfect acoustic seal for superior noise isolation.
    Offers seamless control of your iPhone, iPad, or iPod while listening to music, watching movies and answering phone calls.
  • Tech Specs
    Driver Design
    Driver Design
    KG-2365 AcuPass(R) two-way hybrid
    Driver Components
    KG-723 balanced armature tweeter
    KG-065 dynamic woofer
    Driver KG-723 balanced armature tweeter
    Mic/Remote
    Mic + 3-button remote
    Frequency Response
    10 Hz to 20 kHz
    Sensitivity
    110 dB @ 1 mW
    Impedance
    50 Ohms (1 kHz)
    Noise Isolation
    -26 dB
    Input Connections
    1/8" / 3.5 mm
    Weight
    0.9 oz / 25.0 g
  • In The Box
    • 5 x Pairs of Eartips
    • Clothing Clip
    • Carrying Case
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
