Close Cart
Your cart is currently empty.
Browse:
Noble Dulce Bass Noble Dulce Bass
  • Noble Dulce Bass
Noble Dulce Bass
Noble Dulce Bass
$699.00
  • 5 Knowles© balanced armature drivers per side
  • Updated Noble universal form factor and geometry featuring precision machined aluminum faceplates
  • Sensitive enough for use with smartphones as well as portable amps and DAPs
  • Hand-assembled and matched
  • Detachable cable with industry standard two-pin configuration (0.78 mm diameter)
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    Looking for that sweet, booming bass without sacrificing your audio quality? Then look no further than the Dulce Bass In-Ear Monitor Headphones from Noble Audio.
    The Dulce Bass delivers pumping bass that will make any avid electronic or R&B fan happy. If you are looking to listen to some seriously thumping beats without the usual muddiness that occurs with an increase in low-end, the Dulce Bass is for you. Throw your Beats by D.R.E away and pick up the Dulce Bass today!
    PThe Dulce Bass (which translates to "sweet bass”) is Noble's most bass-heavy configuration designed to deliver visceral low-end response uncharacteristic of balanced armature pieces. A bass-lover’s dream come true, Dulce Bass offers a refined audiophile take on electronic and bass-heavy music.
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
