Close Cart
Your cart is currently empty.
Browse:
Pioneer SE-MONITOR5 Pioneer SE-MONITOR5
  • Pioneer SE-MONITOR5
Pioneer SE-MONITOR5
Pioneer SE-MONITOR5
$999.99
  • Over-ear, closed-back design allowing for excellent noise isolation
  • Large 50mm dynamic drivers offer clear, cohesive sound
  • The bio-cellulose nano-fiber diaphragm is extra-light and strong helping to provide accurate sound
  • Magnesium alloy driver housing for low resonance and strong bass
  • Comfortable, padded headband with adjustable slider
Headphones.com is stoked to be accepting NANO, Bitcoin, Ethereum, Litecoin and many more cryptocurrencies!
  • Description
    Enjoy your music as it was intended with the Pioneer SE-MONITOR5 Hi-Res Stereo Headphones. These fully enclosed dynamic headphones are made with 50mm cellulose nano-fibers and offer a frequency response range of 5 Hz to 85 kHz. The housings are made from magnesium alloy, have double-chamber construction, and float on rubber insulators. Included with the SE-MONITOR5 are three cables, two types of earpads, a 6.3mm adapter, and a carry pouch.
    Cellulose Nano-Fiber Drivers
    The 50mm SE-MONITOR5 drivers are made from cellulose nano-fiber, which is wood-derived pulp that has been finely ground to several hundredths of a micron—and smaller—for high strength and light weight. The material is stiff enough to enable extended high-frequency response, yet absorbs small resonances for faithful and natural source reproduction.
    Base and Housing
    The base and housing of the headphones are made from a rigid magnesium alloy that suppresses distortion-causing vibration, which results in enhanced capacity for deep bass at high volume.
    Double-Chamber Construction
    The main chambers have sculpted diffusers, which channel sound pressure into ported sub-chambers that are vented to release the pressure from the system. This reduces sound pressure behind the driver so it can move as intended, thus generating clean bass response and reducing sound leakage.
    Cables
    Three cables are included with the SE-MONITOR5. 5.2' and 9.8' unbalanced cables are made with dual-braided wires and have gold-plated 3.5mm stereo connectors. The 5.2' balanced cable has dual-braided wires as well, and it terminates in a gold-plated 2.5mm 4-pole stereo connector. This cable splits left and right signals to eliminate crosstalk.
    *Headphones.com is very pleased to announce that you have even more options to pay for your Pioneer SE-MONITOR5 headphones! Now when you hit the Pay with Crypto button, you have the option to pay with cryptocurrencies like NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
  • Tech Specs
    Type
    Driver Type
    Dynamic cellulose nano-fiber
    Driver Size
    1.96" (50 mm)
    Frequency Range
    5 Hz to 85 kHz
    Impedance
    40 Ohms
    Sensitivity
    99 dB
    Maximum Input Power
    1000 mW
    Cables
    Cable 1
    Unbalanced OFC Litz wire, 5.2' (1.6 m) with 3.5 mm gold-plated stereo mini-plug
    Cable 2
    Unbalanced OFC Litz wire, 9.8' (3.0 m) with 3.5 mm gold-plated stereo mini-plug
    Cable 3
    Balanced OFC Litz wire, 5.2' (1.6 m) with 2.5 mm gold-plated, 4-pole stereo super mini-plug
    Weight
    Without Cable: 1.06 lb (0.48 kg)
  • In The Box
    • Pioneer SE-MONITOR5 Hi-Res Stereo Headphones
    • 5.2' Unbalanced Cable
    • 9.8' Unbalanced Cable
    • 5.2' Balanced Cable
    • Velour-Type Earpads
    • Leather-Type Earpads
    • 6.3mm Standard Stereo Plug Adapter
    • Carry Pouch
    • Limited 1-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Base and Housing
Cables
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
