Close Cart
Your cart is currently empty.
Browse:
Pioneer XDP-300R Pioneer XDP-300R
  • Pioneer XDP-300R
  • Pioneer XDP-300R
Pioneer XDP-300R
Pioneer XDP-300R
$699.00
  • Plays MP3, MQA, FLAC, WAV, ALAC, Ogg Vorbis, AAC, and AIFF
  • Dual ESS Sabre® ES9018K2M 32-bit/192kHz DACs for bit-perfect playback of high-resolution audio files
  • Dual ESS Sabre® 9601K headphone amplifiers for clean, powerful sound via the balanced or unbalanced headphone outputs
  • Streams internet videos from sources like YouTube
  • Ability to stream direct from sources like Spotify, Tidal, etc...
  • Android™ OS 5.1 with Google Play™
  • Built-in internet browser
  • 32GB internal flash memory with dual 200GB microSDXC slots for up to an extra 400GB of memory
  • Built-in rechargeable battery provides up to 16 hours of playback
Headphones.com is proud to be an early adopter accepting payments online via cryptocurrency.
A portion of all sales from Headphones.com will be donated to help children with hearing loss.
Learn More
  • Description
    Playback a Multitude of High Quality Audio Sources
    The XDP-300R supports all your current audio from MP3’s to streaming music from your favorite internet apps. With playback support for up to 11.2MHz DSD, 384kHz/24 bit PCM, FLAC, ALAC, WAV, AIFF, and MQA it is possible to enjoy many existing Hi-Res audio formats. Equipped with both 2.5 mm balanced output and 3.5 mm headphone output; audio can also be output via Micro USB-B/OTG digital output, and wireless output to connect the XDP-300R offers a wide selection of headphones and peripherals.
    Compatible Formats:
    DSD(DSF/DSDIFF)/FLAC/ALAC/WAV/AIFF/MQA/OggVorbis/MP3/AAC
    High Resolution Playback with Twin DAC & Amp Setup
    Incorporating twin unit ESS Technology DAC “ES9018K2M” and AMP “SABRE 9601K” each allows for extreme high resolution audio and component audio design philosophy while still maintaining a realistic power envelop for a portable device.
    Independent Audio Circuit Board
    Complete separation between the audio circuit board (DAC & AMP) and CPU board to allow for internally separated construction. Within the DAC & AMP board, the audio circuitry and switching power are distanced as far as physically possible to limit the effects of noise. The DAC & AMP have their own capacitors to provide a clean audio signal with its closed loop design. Attention was made to circuit design to keep digital noise from getting in between you and your music.
    Two types of Balanced Drives
    Balanced output via the 2.5mm 4 pole supports the standard “BTL” drive as well as “ACG (Active Control GND)” drive. ACG drive is a different form of balanced drive where the amp’s COLD side actively drives to create an ideally stable GND. Power gains and increased sound separation associated with balanced output are repurposed to create increased stability for a clean signal and a greater sound clarity, especially compared to unbalanced drive.
    High Precision EQ-HD
    With up to 16,384 discrete bands to select from, and the ability to save up to 1,000 EQ profiles, the linear-phase FIR equalizer offers high definition equalization with zero loss in audio quality.
    Intuitive GUI Interface
    The capacitive touch screen incorporates a GUI that allows for swiping vertically between your often accessed playlists and equalizer settings at the flick of your finger. There is also a selectable GUI to display full color album art and rearranging of the button layout to the lower half of the screen for easier one handed operation.
    Large capacity storage and battery life
    Equipped with 2 micro SD card slots (up to 200GBs each), the internal memory of 32GBs (including system area), have access to up to 432GBs of storage for music, movies, and apps. With up to 16 hours (96kHz/24 bit FLAC unbalanced playback) of Hi-Res audio playback, play to your heart’s content.
    High quality audio, wirelessly
    Tether to your smartphone via Wi-Fi to enjoy Hi-Res audio streaming. Enjoy high quality sound wirelessly using Bluetooth and aptX.
  • Tech Specs
    Audio
    DAC
    2 x ES9018K2M 24-Bit
    Amplifier
    2 x SABRE 9601K
    External DAC Functionality
    Audio Resolution
    DSD128
    11.2 MHz / 24-Bit
    PCM
    384 kHz / 24-Bit
    Frequency Response
    20 Hz - 80000 Hz
    Impedance
    Unbalanced
    16 - 300 Ohms
    Balanced
    32 - 600 Ohms
    Gain Settings
    High1
    Normal
    Low1
    Low2
    Volume Control
    Analog (161 Steps)
    Audio Power Output
    75 mW (Unbalanced)
    150 mW (Balanced)
    Signal to Noise Ratio
    >115 dB
    Custom Equalizer
    Performance
    Operating System
    Android 5.1
    Internal Storage Capacity
    32 GB
    Maximum Storage Capacity
    400 GB
    Flash Media Slot
    2 x microSD
    Display
    4.7" LCD (1280 x 720 Resolution)
    Media Support
    Video Playback
    Formats Supported
    Audio
    DSD(DSF/DSDIFF)
    FLAC
    ALAC
    WAV
    AIFF
    MQA
    OggVorbis
    MP3
    AAC
    Video
    H.263/H.264
    AVC/H.265
    HEVC/MPEG-4
    SP
    VP8
    VP9VP8
    VP9
    JPEG
    GIF
    PNG
    BMP
    WebP
    Wireless
    Bluetooth 2.0 A2DP
    Bluetooth 2.0 AVRCP
    Bluetooth HID
    Wi-Fi (802.11a/b/g/n/ac)
    Bluetooth Codecs
    aptX
    Connections
    2.5 mm Balanced Headphone
    1/8" (3.5 mm) Stereo Headphone
    Micro-USB 2.0
    Built-In Mic
    Power
    Battery
    1x Built-in Rechargeable Lithium-ion Battery 1630 mAh
    (Providing up to 16 Hours per Charge for Audio Playback)
    Charger
    USB 2.0
    General
    IP Rating
    None
    Temperature
    Operating
    41 to 95°F (5 to 35°C)
    Dimensions (W x H x D)
    3.0 x 5.1 x 0.5" / 75.9 x 128.9 x 13.0 mm
    Weight
    7.05 oz / 200 g
  • In The Box
    • Pioneer XDP-300R high-resolution portable audio player
    • 40" micro USB-to-USB cable
    • quick start guide
    • warranty information
    • "Wi-Fi and bluetooth function" note
    • onkyo music brochure
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Compatible Formats:
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
