Sennheiser G4ME ZERO Closed-Back Gaming Headset - headphones.com
Color
Black
White
  • The Sennheiser G4ME ZERO is a gaming-grade headset featuring ear pads made from thick leatherette and triple-layered memory foam. The base of the ear pads are thicker so that the headset closes around your ears to prevent noise from escaping and keeping background noise out. All this is designed to help fully immerse you in game play. The headset's noise canceling microphone cuts out background noise for clear communication. For easy access, volume controls are built into the right ear cup, and there is also a microphone mute function. Additionally, the headphones can be completely folded up and stored in the included hard carry case.
    Design
    G4ME ZERO differs from the G4ME One with their closed back design. These wonderfully made headsets feature a new ear pad design, which Sennheiser has further developed from their professional pilot headsets. The ear pads are made from thick leatherette and triple-layered memory foam. The base of the ear pads are thick to ensure that the headset closes all around the ear. This prevents sound from escaping and keeps you from being disturbed by outside noise.
    German Engineered Technology
    The G4ME ZERO has two transducers that are optimized to provide an extremely accurate reproduction of the gaming audio no matter what type of game you play. Each unit is mechanically and acoustically tested to provide the quality Sennheiser sound you have come to know and love.
    Noise Cancelling
    Microphone provides noise cancellation for clear chatting so that your allies and foes alike can always hear your, regardless of the noise from the outside world.
    Intuitive Controls
    Volume controls are built into the right ear cup for easy access. There is a microphone mute function as well - simply lift the boom arm to mute it.
    Collapsible Design and Carry Case
    The headphones can be completely folded up and stored in the included hard carry case.
    No Need for an Amplifier
    Sennheiser improved upon their older version of the G4ME Zero. These headphones used to have a 150 ohm impedance and would not be driven properly by a PS4 or Xbox. However, their new and improved headphones only have a 50 Ohm impedance, making it as simple as plug and play for amazing gaming sound.
    Detachable Cables Based on Your Needs
    The G4ME Zero from Sennheiser comes with two detachable cables. The longer one specifically for PC gaming and the shorter cable is for console gaming. The PC cables features two 3.5mm plugs, one for the headset and for the mic to be plugged into your PC ports. The console game features a single 3.5mm plug so you can plug directly into your PS4 or Xbox One controller and still have the full functionality of the headphones and microphone. An additional adapter can be purchased for the PC cable so that you may use the longer cable for console gaming.
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
Free Headphone Stand With Your First Order
