Close Cart
Your cart is currently empty.
Browse:
Sennheiser GSX 1000 Sennheiser GSX 1000
  • Sennheiser GSX 1000 7.1 Audio Amplifier for PC and Mac - headphones.com
Sennheiser GSX 1000
Sennheiser GSX 1000
$229.95
  • 7.1 Virtual Surround Sound
  • Dedicated DAC Chip
  • USB Connectivity
  • LED Touch Display
  • 3 x 3.5mm Audio Jacks
  • USB Cable Included
  • Windows and Mac Compatible
loading
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    Designed primarily for gaming, the GSX 1000 audio amplifier features a Sennheiser Binaural Rendering Engine. The groundbreaking 7.1 Virtual Surround Algorithm was developed with the needs of professional gamers in mind. Experience surround sound on a new level.
    Surround Sound Reborn
    Designed primarily for gaming, the GSX 1000 audio amplifier features a Sennheiser Binaural Rendering Engine. The groundbreaking 7.1 Virtual Surround Algorithm was developed with the needs of professional gamers in mind. Experience surround sound on a new level. It works with PC and Mac.
    Change Sound Settings on the Fly
    The stylish and durable GSX 1000 features an intuitive LED touch panel and aluminum volume ring for rapid fingertip control of your sound, and requires no additional drivers – so there’s no need to tab out of the game to tweak your settings. You also have the possibility to save up to 4 favorite settings.
    Exceptional Immersion
    The GSX 1000 has been designed to be the heart of your gaming sound, with a dedicated DAC chip that requires no additional drivers. The amplifier gives precise control of both game and communication sound, allowing for separate adjustment and USB inputs for each. Besides the range of EQ settings, it is also possible to set Reverberation levels to change how the user feels in physical spaces of the game.
    Intuitive Audio Control
    The red on black display dims down when not in use to cut the distractions, and brightens the instant it senses your hand is near. It allows you to instantly adjust the Sidetone to change how loud your own voice sounds, and to switch between headset and speaker sound without unplugging cables.
    • USB Connectivity
    • LED Touch Display
  • Tech Specs
    Supported Sample Rate
    Main Audio
    7.1
    44.1 kHz @ 16-bit
    48 kHz @ 16-bit
    2.0
    44.1 kHz @ 16-bit
    48 kHz @ 16-bit
    96 kHz @ 24-bit
    Main Audio HD
    2.0
    96.0 kHz @ 24-bit
    Communication Audio
    1.0
    6 kHz @ 16-bit
    Headphone Outputs
    Frequency Response
    0 to 48 kHz
    Impedance
    16 to 150 Ohms
    Max. Output Voltage
    1 V RMS @ 32 Ohms
    Headphone
    DC coupled
    Dual rail power supply
    General
    USB
    USB 2.0 full speed
    USB 1.0 audio
    Total Harmonic Distortion
    0.005% @ -3 dBFS
    Ports
    1 x 3.5 mm headset
    1 x 3.5 mm microphone
    1 x 3.5 mm loudspeaker
    1 x mini-USB
    Line Out Frequency Response
    1.5 Hz to 48 kHz
    Max. Output Voltage
    1 V RMS @ 10 Ohms
    Cable Length
    USB Cable
    3.9' / 1.2 m
  • In The Box
    • GSX 1000 audio amplifier
    • USB cable
    • Quick Start Guide
    • Safety Guide
    • 2-year warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
  • USB Connectivity
  • LED Touch Display
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
