Close Cart
Your cart is currently empty.
Browse:
Sennheiser GSX 1200 PRO Sennheiser GSX 1200 PRO
  • Sennheiser GSX 1200 PRO 7.1 Audio Amplifier for PC and Mac - headphones.com
$249.95
  • 7.1 Virtual Surround Sound
  • Dedicated DAC Chip
  • Hard-Wired Lag-Free Communication
  • USB Connectivity
  • LED Touch Display
  • 3 x 3.5mm Audio, 2 x 2.5mm Chat
  • USB and Chat Cables Included
  • Windows and Mac Compatible
loading
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    Designed for the competitive eSports arena, the GSX 1200 PRO Audio Amplifier from Sennheiser features a groundbreaking 7.1. Virtual Surround Algorithm. Experience Surround Sound on a new level.
    Ultimate Positional Gaming Audio
    Designed for the competitive eSports arena, the GSX 1200 PRO audio amplifier features a groundbreaking 7.1. Virtual Surround Algorithm. Experience Surround Sound on a new level. Precise control of both game and communication sound is allowed by separate adjustment of - and switching between -headphones and speakers without having to unplug the cables. Get ready for the tournament and connect up to 8 GSX 1200 PROs together for hard-wired lag-free communication, and control of inbound and outbound chat. It works with PC and Mac.
    Change Sound Settings On The Fly
    Featuring the red LED-lit touch panel display surrounded by a durable aluminum volume wheel, the GSX 1200 PRO radiates a sense of potency, purpose and total focus on the gaming experience. The crystal-clear display takes inspiration from the instrumentation on performance cars or fighter planes – giving fast immediate information and allowing players to rapidly adjust sound on the fly.
    Hear Everything. Own The Game
    The GSX 1200 PRO has been designed to be the heart of your gaming sound, with a dedicated DAC chip that requires no additional drivers. The amplifier give precise control of both game and communication sound, allowing for separate adjustment and USB inputs for each. Besides the range of EQ settings, it is possible to set Reverberation levels to change how the user feels in physical spaces of the game, and even increase the surround speakers for back and front speaker focus.
    Game Changing Intuitive Control
    The red on black display dims down when not in use to cut the distractions, and brightens the instant it senses your hand is near. It allows you to instantly adjust the Sidetone to change how loud your own voice sounds, and to switch between headset and speaker sound without unplugging cables.
    Designed for competitive eSports arenas, the GSX 1200 PRO has been created by Sennheiser specifically for professional gamers, adding tournament-ready features such as Chat Link - the ability to connect up to 8 GSX 1200 PROs together for hard-wired lag-free communication.
    • USB Connectivity
    • LED Touch Display
  • Tech Specs
    General Data
    USB
    standard 2.0 USB Full Speed & 1.0 USB Audio
    Total harmonic distortion (THD)
    0.005 % THD
    Cable length
    USB Cable
    1.2 m
    Chat Cable
    2.0 m
    Connector plugs
    3.5mm headset socket
    3.5mm microphone socket
    3.5mm loudspeaker socket
    mini-USB socket
    2.5mm chat interface socket A
    2.5mm chat interface socket B
    Supported sample rates
    Main Audio
    7.1
    44.1 kHz @ 16 bit
    48.0 kHz @ 16 bit
    2.0
    44.1 kHz @ 16 bit
    48.0 kHz @ 16 bit
    Main Audio HD
    2.0
    96.0 kHz @ 24 bit
    Communication Audio
    1.0
    16.0 kHz @ 16 bit
    Audio outputs
    Headphone
    DC coupled
    Dual rail power supply
    Frequency response
    0 – 48.0 kHz
    Recommended headphone impedance
    16 – 150 Ω
    Max. output voltage
    1 V RMS @ 32 Ω
    Line out (AUX)
    Frequency response
    1.5 – 48.0 kHz
    Max. output voltage
    1 V RMS @ 10 kΩ
  • In The Box
    • GSX 1200 PRO audio amplifier
    • Chat cable
    • USB cable
    • Quick Start Guide
    • Safety Guide
    • 2 year warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
  • USB Connectivity
  • LED Touch Display
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
