Close Cart
Your cart is currently empty.
Browse:
Sennheiser HD 1 Over-Ear Wireless Sennheiser HD 1 Over-Ear Wireless
  • Sennheiser Momentum 2 Bluetooth Over-Ear Wireless Headphone with Integrated Microphone (Black) - Premium Sound Canada
  • Sennheiser HD 1 Bluetooth Over-Ear Wireless Headphone with Integrated Microphone - headphones.com
$399.95
  • Bluetooth 4.0 + EDR
  • Genuine Leather Earcups
  • NoiseGard Attenuates Ambient Noise
  • Built-In VoiceMax Microphone
  • Built-In Rechargeable Battery
loading
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The Sennheiser HD 1, a winning combination of uncompromised performance, pure minimalistic style and luxurious high-quality materials, such as genuine leather ear cups, has now gained even more appeal by becoming the HD 1 Wireless Over-Ear. The hybrid active NoiseGard™ attenuates ambient noise, while the highdefinition aptX® codec carves out every aural nuance in finest detail. Furthermore, the built-in VoiceMax microphone enables you to conduct crystal clear conversations.
    The new Sennheiser HD 1 Wireless lets you experience crystal-clear HD 1 sound without being attached to a cable. It combines high-resolution sound with a lightweight, puristic design and exclusive materials like stainless steel and real leather.
    High-Resolution Audio that will make you feel
    While the hybrid active NoiseGard™ attenuates ambient noise, the high-definition aptX® codec carves out every aural nuance in even finer detail. Thus, the trademark HD 1 sound becomes still more brilliant. Furthermore, the VoiceMax microphone, as an integral part of the headphones, enables you to conduct crystal-clear conversations without the need of an external microphone.
    Experience a whole new quality in wireless sound. With the new HD 1 Wireless. Its large diaphragms and innovative technology deliver full HD 1 sound in new perfection. Clear, richly detailed and with a powerful bass.
    Advanced and Smart
    With the HD 1 Wireless setting up a wireless connection is even easier than to plug in a conventional cable. It is implemented via the integrated NFC™ at the push of a button. In an instant, thanks to Bluetooth® 4.0 standard. Connect and enjoy the sound.
    Timeless and Immaculate
    Love of detail is a main character trait of the Sennheiser HD 1 Wireless: With sliders made of stainless steel, and luxurious leather covering the soft, newly designed ear cushions. Its sound and its finish with accurately placed seams make the HD 1 a delight for all senses.
    Without a cable the HD 1 becomes even more puristic, reduced to the max – maximum listening pleasure.
    Comfort and Style that fits you
    The ear cups of the new HD 1 Wireless are attached to high-end ball joints running steplessly in collapsible sliders made of brushed stainless steel. The individual adjustment to the head is important for both comfort and sound. And with its newly designed ear cups the HD 1 offers even more wearing comfort.
    Thanks to high-quality materials the mechanical components of the Sennheiser HD 1 Wireless are especially durable and elegant.
    Optional and Optimized
    The new HD 1 Wireless can also be operated with a cable, just like any conventional headphones. The design of the jack plug, however, is not conventional at all: Its especially low profile was optimized for the use on mobile devices.
    Fitted with jack plugs on both ends, the cable is completely detachable and can be replaced if necessary.
  • Tech Specs
    General data
    Bluetooth Version
    Bluetooth 4.0
    EDR
    Supported Profiles
    A2DP
    AVRCP
    HSP
    HFP
    Ear cup design
    over-ear
    Jack plug
    3.5 mm, angled
    Cable length
    1.4 m (Detachable)
    Transducer principle
    Dynamic, closed-back
    Attenuation
    Up to 25dB
    Charging time
    Approx. 3 hrs
    Operating time
    22hrs (HFP + ANC)
    Battery Specification
    Rechargeable Lithium-ion Polymer (600mAh)
    Codecs
    apt-X®
    NoiseGard™ noise compensation
    NoiseGard™ Hybrid technology with 4 pick-up microphones
    Headphones
    Impedance
    passive
    28 Ω
    active
    480 Ω
    Frequency response
    16 Hz – 22000 Hz
    total harmonic distortion (THD)
    < 0.5%
    Contact pressure
    Approx. 3.6 N
    Microphone
    Frequency response (microphone)
    Wideband
    100 - 8,000Hz
    Narrowband
    300 - 3,400Hz
    Pick-up pattern
    Dual omni-directional microphone (2 mic beamforming array)
  • In The Box
    • Sennheiser HD 1 Over-Ear Wireless headphones
    • 1.4 m Audio cable / 3.5 mm Low-profile angled plug
    • USB Charging cable
    • Inflight adapter
    • Manuals
    • Carrying case
  • Reviews
    Customer Reviews
    Based on 1 review
    100%
    (1)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    J
    J.
    Awesome sound and fit
    Very easy to use the bluetooth, battery life is great, very comfortable, and amazing sound. Going through my whole music collection cause it's so fun to listen to everything.
Advanced and Smart
Customer Reviews
Based on 1 review
100%
(1)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
J
J.
