Close Cart
Your cart is currently empty.
Browse:
Sennheiser HD 380 Pro Sennheiser HD 380 Pro
  • Sennheiser HD 380 Pro Circumaural Monitoring Headphones - headphones.com
$149.95
  • Closed-Back, Over-Ear Design for great noise isolation
  • E.A.R. Technology
  • Duofol Diaphragms
  • Noise Isolating
Headphones.com is stoked to be accepting NANO, Bitcoin, Ethereum, Litecoin and many more cryptocurrencies!
  • Description
    The HD 380 Pro headphones from Sennheiser provide professional-quality sound in a rugged and lightweight design. The headphones use E.A.R. (Ergonomic Acoustic Refinement) technology and patented Duofol diaphragms to reduce comb filter effects and distortion, to provide you with clear, natural sound with plenty of detail.
    The headphones have a closed-back design with thick around-ear cushions to provide up to 32dB of natural noise isolation, as well as long-lasting comfort. The padded headband is adjustable to fit virtually any head size for a snug fit. The single-sided coiled cable provides a variable amount of slack and is resistant to tangles. It is also detachable for easy replacement. The standard 3.5mm stereo mini plug and screw-on 1/4" adapter provide wide compatibility with a variety of consumer and professional audio devices. A slimline carrying case is also included.
    • E.A.R. Technology
    • Duofol Diaphragms
    • Noise Isolating
  • Tech Specs
    Type
    Driver
    Frequency Range
    8Hz - 27kHz
    Impedance
    54 Ohms
    Sensitivity
    110dB
    Maximum Input Power
    500mW
    Connectors
    Standard 3.5mm Stereo Mini Plug with 1/4" Adapter
    Cable Length
    3.3' (1 m) (Coiled)
    10' (3 m) (Stretched)
    Weight
    7.7 oz (220g) (Without Cable)
  • In The Box
    • Sennheiser HD 380 Pro Headphones
    • Replaceable single sided, coiled cable with a 3.5mm jack connector
    • Screw-type 1/4" adapter
    • Carrying case
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
  • E.A.R. Technology
  • Duofol Diaphragms
  • Noise Isolating
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
