Sennheiser HD 700 Open-Back Over-Ear Audiophile Headphones
Color
Black
  • The HD 700 Stereo Headphones from Sennheiser are focused on delivering the most pure audio reproduction possible. The headphones have angled transducers that mimic the positioning of a set of reference monitor speakers. This angling, along with the DuoFol transducers, provides a wide sound stage with incredibly fast response and rest times.
    The headphones also have a patent-pending ventilated magnet system. By venting the magnet behind the diaphragm, airflow is properly managed to minimize turbulence and distortion. The outer chassis has an open-aire design with a special steel mesh to maintain purity while properly directing airflow. The final piece of the puzzle is the vibration dampening frame, which prevents unwanted resonances from entering the acoustic chamber. The result is audio that is balanced, natural, and detailed.
    The headphones have thick cushions that fit around the ears, plus an adjustable headband so you can listen in comfort for hours at a time. The extra-long cable provides plenty of slack, ideal for listening at home or in a studio. The 1/4" stereo plug connects to a variety of A/V receivers, stereo systems, and other devices. The headphones arrive to you in a luxurious storage box to protect the headphones when they're not in use.
    Pure Sound
    • A focus on purity delivers audiophile-grade sound that is balanced, natural, and detailed
    Angled Transducers
    • The angled transducers mimic the positioning of a set of reference monitor speakers to provide a wide sound stage
    DuoFol Diaphragms
    • The DuoFol diaphragms deliver a wide frequency response and have incredibly fast response and rest times
    Ventilated Magnet System
    • The patent-pending ventilated magnet system properly manages the airflow to minimize turbulence and distortion
    Steel Mesh
    • The outer chassis has an open-aire design with a special steel mesh that's molded to the shape of the acoustic chamber to maintain purity while properly directing airflow
    Vibration Dampening Frame
    • The vibration dampening frame uses strategic layering of materials to prevent unwanted resonances from entering the acoustic chamber
    Comfortable Fit
    • The headphones have thick cushions that fit around the ears, plus an adjustable headband so you can listen in comfort for hours at a time
    Extra-Long Cable
    • The extra-long 9.8' cable provides plenty of slack, ideal for listening at home or in a studio
    1/4" Plug
    • The 1/4" stereo plug connects to a variety of A/V receivers, stereo systems, and other devices
    Storage Box
    • The headphones arrive to you in a luxurious storage box to protect the headphones when they're not in use
Subscribe
