Sennheiser IE 60 In-Ear Stereo Headphones
Color
Black
  • The IE 60 In-Ear Stereo Headphones from Sennheiser provide high-grade audio in a stylish and ergonomic package. The compact housings each contain a single dynamic driver with neodymium magnet to provide warm, natural audio with a wide frequency response and excellent efficiency.
    The headphones come with 2 different types of eartips, each with 3 different sizes so you can find the perfect in-ear fit. A proper fit creates a seal in the ear to reduce ambient noise by as much as 20dB. This also helps to improve bass response and allows you to listen at lower volume levels without missing out on the details in your music.
    Optional flexible earhooks are included for a secure fit. The durable cable provides plenty of slack, and can also be looped around the ears for additional stability. The headphones can be worn in a traditional manner as well. An included cable clip lets you attach the cable to your clothing to minimize snags, tangles, and friction noise. The 3.5mm stereo mini plug has angled strain relief to provide lasting durability. A cleaning tool and hardshell storage case are included to keep your headphones in great condition for years of enjoyment.
    Lightweight Design
    • The stylish and lightweight design is ideal for travel
    Excellent Sound Quality
    • The compact housings contain single dynamic drivers with neodymium magnets to provide warm, natural audio with a wide frequency response and excellent efficiency for a full-bodied audio experience
    In-Ear Fit
    • The headphones come with latex-free silicone and lamella eartips, each in 3 different sizes so you can find the perfect in-ear fit. A proper fit creates a seal in the ear to reduce ambient noise by as much as 20dB. This also helps to improve bass response and allows you to listen at lower volume levels without missing out on the details in your music
    Stability
    • Optional flexible earhooks are included for a secure fit
    Robust Cable
    • The durable cable provides plenty of slack, and can also be looped around the ears for additional stability. The headphones can be worn in a traditional manner as well
    Cable Clip
    • The included cable clip lets you attach the cable to your clothing to minimize snags, tangles, and friction noise
    Standard Plug
    • The 3.5mm stereo mini plug has angled strain relief to provide lasting durability. It offers compatibility with a wide variety of MP3 players, CD players, laptops, tablets, and more
    Accessories
    • A cleaning tool and hardshell storage case are included to keep your headphones in great condition for years of enjoyment
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
Free Headphone Stand With Your First Order
