Sennheiser MOMENTUM True Wireless Earbuds
- Bluetooth 5.0 compliant
- Supports AAC, aptX, aptX-LL, and SBC codecs
- 7mm dynamic drivers yield a frequency range of 5 Hz to 21 kHz
- Dual MEMS microphones utilize beamforming technology for enhanced clarity and consistency of your voice
- Built-in LiPo rechargeable batteries deliver up to 4 hours of operating time without the charging case, or up to 12 hours of use with the charging case
- Quickly recharge via USB Type-C in approximately 1.5 hours
- IPX4 rating for splash resistance (excluding charging case)
- Sennheiser Smart Control app available for iOS and Android
- Includes charging case, USB Type-C charging cable, and multiple pairs of silicone ear adapters
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
Available for Pre-Order Now! Order now to get yours as soon as they arrive!
Sennheiser is back with a new addition to their very popular Momentum line-up. Introducing the Sennheiser Momentum True Wireless headphones, an exquisite pair of truly wireless earbuds that represents a new shift in the truly wireless earbud market.
The Sennheiser Momentum True Wireless headphones are beautiful to behold and feature the all new Bluetooth 5.0 technology. These are truly wireless earbuds made by audiophiles, for audiophiles.
These attractive earbuds, with Sennheiser’s audiophile driver technology, guarantee superior stereo sound performance at all times. Thanks to advanced Qualcomm apt-X Low Latency compatibility, you can experience media with perfectly lip-synced audio, whilst 2-mic noise cancellation beamforming technology and Transparent Hearing allows you to always be aware of your surroundings, with or without your music on.
These earbuds are lightweight (13.2 grams for both earbuds!), splash resistant and have a built in intuitive touch control that makes all of your on-the-go listening seamless and comfortable. The Momentum True Wireless earbuds are made to fit your lifesytle needs.
Not only are these some of the best truly wireless earbuds on the planet, they are also some of the best looking too. With premium black housing, a polished metallic spin ring and gold-plated charging pins, function meets fashion in iconic design.
With the Sennheiser Momentum True Wireless earbuds comes Senneheiser's latest app, Senneiser Smart Control. This free dedicated app for iOS and Android provides an effortless way to control, personalize, update and configure your headphone, headset or soundbar.
Tech Specs
- Dimensions:
- 78.6 x 45 x 35 mm (charging case)
- Microphone:
- MEMS
- Bluetooth Version:
- Bluetooth 5.0 compliant, class 1
- Supported Profiles:
- A2DP, AVRCP, HSP, HFP
- THD, total harmonic distortion:
- <0,08% (1kHz / 94dB)
- Ear coupling:
- Ear Canal
- Weight:
- 69.8 g (earbuds and charging case), 13.2 g (both earbuds), 56.6 g (charging case)
- Charging time:
- Approx. 1.5 hrs
- Microphone sensitivity:
- 94 dB SPL at 1 kHz
- Operating temperature:
- 0 to +40°C
- Power supply:
- 5 V, 650 mA: USB charging via USB-C socket at charging case
- Battery Specification:
- Built-in Lithium rechargeable battery
- Frequency range:
- Earbuds: 5 Hz to 21 kHz
Microphone:100 Hz to 10 kHz (microphone) - Sensitivity:
- 107 dB SPL (1 kHz / 1 mW)
- Speaker type:
- Dynamic
- Operating relative humidity:
- 10 to 80%, non condensing
- Battery time:
- Up to 4 hrs (A2DP) with rechargeable batteries of the earbuds, Up to 12 hrs with rechargeable battery of the charging case
- Water Protection Code:
- IPX4, splash resistant (earbuds)
- Type of Codec:
- SBC, aptX™, aptX™ Low Latency, AAC
In The Box
- MOMENTUM True Wireless earbuds
- Silicone ear adapter sets (in size (XS/S/M/L)
- Charging case
- USB-C charging cable 20 cm
- Manuals (Safety Guide & Quick Guide)
