Sennheiser RS 195 Digital Wireless Headphone System - headphones.com
No reviews
Color
Black
Giving you clear signal transmission with low latency, the RS 195 Digital Wireless Headphone System from Sennheiser is comprised of a pair of HDR 195 headphones and a TR 195 transmitter that also serves as a docking and charging station for the headphones. Hearing boost presets help you boost dialog clarity and suppress noise from your source audio. The system provides up to a 328' range of operation and features both analog and digital inputs for compatibility with a variety of home entertainment systems. A pair of rechargeable batteries, analog and optical cables, and a power supply are included.
  • Closed, circumaural headphones with excellent digital wireless audio transmission
  • Digital audio clarity and transmission range of up to 328' (100 m) , line of sight
  • Selectable hearing boost presets and an additional noise suppression mode for clearer dialogues and speech intelligibility
  • Choose the music listening mode which reproduces music with an increased dynamic range to preserve the sound image
  • Supports analog and digital audio inputs and allows toggling between the inputs
  • Multi-purpose transmitter - also functions as 'easy-charge' cradle and docking station
  • Balance control for right/left volume adjustment
  • Ergonomic design
Specifications
Headphones
  • Frequency Response: 17 Hz to 22 kHz
  • Maximum SPL: 117 dB at 1 kHz, 3% THD
  • THD: <0.5 at="" 1="" khz="" 100="" db="" spl="" p="">
  • Transducer Principle: Dynamic, closed
  • Operating Time: Up to 18 hours
  • Weight: 12 oz (340 g), including batteries
Transmitter
  • Audio Input: 1x 1/8" (3.5 mm) stereo analog input, 1x Optical digital input
  • Power Consumption: ≤ 0.3 W (standby)
System
  • Range: Up to 328' (100 m)
  • Signal to Noise Ratio Analog Input: 85 dBA at 1 Vrms, typical
  • Digital Input: > 90 dBA
  • Modulation: 8-FSK Digital
  • Carrier Frequency: 2.4 to 2.48 GHz
Packaging Info
  • Package Weight: 3.65 lb
  • Box Dimensions (LxWxH): 10.1 x 9.4 x 6.0"
In The Box
  • Sennheiser RS 195 Digital Wireless Headphone System
  • HDR 195 Headphones
  • TR 195 Transmitter
  • Digital Optical Cable
  • Analog Audio Cable
  • Power Supply
  • 4 x Adapters (EU, UK, US & AU)
  • 2 x AAA NiMH Rechargeable Batteries
  • Limited 2-Year Warranty
Subscribe
10% off Your First Order!
