Close Cart
Your cart is currently empty.
Browse:
Sennheiser Urbanite XL Sennheiser Urbanite XL
  • Sennheiser Urbanite XL Bluetooth Headphones (Black) - Premium Sound Canada
$299.95
  • Over-Ear Design
  • NFC Pairing
  • Built-In Rechargeable Battery
  • Up to 25 Hours of Playback
  • aptX, SBC Codecs
  • Stereo Connector Cable
  • Soft Pouch
Headphones.com is stoked to be accepting NANO, Bitcoin, Ethereum, Litecoin and many more cryptocurrencies!
  • Description
    Designed to provide the ample bass response of their Urbanite line without the need for wires, the black Urbanite XL Bluetooth Headphones from Sennheiser feature Bluetooth 4.0 along with aptX and SBC codecs for higher-fidelity playback from compatible Bluetooth devices. Additionally, the headphones are NFC compatible for touch pairing with NFC-enabled devices.
    Headphone-mounted touch controls allow you to adjust volume as well as change tracks and answer calls without the need for an additional remote. For compatiblity with wired sources, a universal remote cable is included, along with a USB charging cable and a soft pouch.
    Wireless Freedom
    The Urbanite XL Wireless headphones add Bluetooth and NFC to the Urbanite formula. Setup is a tap away thanks to its NFC technology, which allows Bluetooth pairing to NFC compatible devices. Use of the Bluetooth 4.0 standard enables multi-connectivity pairing up to 8 different devices as well as simultaneous connection to 2 devices
    Touch Control Panel
    Urbanite XL Wireless includes a touch control panel on the headphone: just slide your finger to adjust the volume or tap to control music and calls
    Bass Without Compromised Clarity
    The Urbanite XL Wireless is designed to deliver an accentuated bass response while still ensuring excellent clarity through the entire frequency range
    Featuring the apt-X codec, the Urbanite XL Wireless can connect wirelessly to any Bluetooth apt-X-enabled device.
    • Over-Ear Design
    • NFC Pairing
    • aptX, SBC Codecs
    • Soft Pouch
  • Tech Specs
    Headphones
    Type
    Over-Ear
    Frequency Response
    16 Hz - 22 kHz
    Impedance
    18 ohms
    SPL
    110 dB @ 1 kHz (1 Vrms)
    Total Harmonic Distortion (THD)
    < 0.5% (1 kHz 100 dB)
    Battery Type
    Li-Polymer
    Bluetooth Version
    4.0
    Bluetooth Profiles
    Headset 1.2
    Hands-free 1.6
    GAVDP
    A2DP 1.2
    AVRCP 1.4
    Range
    Up to 33' (10 m)
    Microphone
    Frequency Response
    100 Hz to 10 kHz
    Pick Up Pattern
    Dual Microphone Array
    Sensitivity
    -42 dB V/Pa
  • In The Box
    • 3.9' (1.2 m) Universal Remote Cable
    • USB Charging Cable
    • Soft Pouch
    • Limited 2-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Wireless Freedom
Touch Control Panel
  • Over-Ear Design
  • NFC Pairing
  • aptX, SBC Codecs
  • Soft Pouch
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
