Ultrasone Signature PRO Closed-Back Over-Ear Stereo Headphones - headphones.com
Color
Black
  • The Ultrasone Signature PRO Closed-Back Stereo Headphones bring you beautiful craftsmanship, modern technology, and outstanding audio quality in an elegant package. Hand crafted in Germany with the utmost attention to detail, the Signature Pro headphones come in a custom case for storage and transportation. The dark grey ear cushions and headband are made from genuine Ethiopian sheepskin leather, which provides a high degree of softness and smoothness. This leather also provides a high degree of natural noise isolation. The closed-back housings have polished safety glass name plates to emphasize a professional focus.
    The 40mm titanium-plated drivers have neodymium magnets to provide an ultra-wide frequency response to bring out the deepest bass and clearest treble in your music, ideal for monitor reference, engineering, mastering, and audiophiles. MU metal bufferboard shielding technology helps to reduce magnetic field emissions by up to 98%, in accordance with ULE standards.
    The headphones also have Ultrasone's S-Logic Plus Natural Surround Sound technology, which pushes the sound around your head to create an enveloping response that creates a high degree of space and realism. Decentralized driver positioning allows the headphones to take advantage of the shape of the ear. Instead of directing sound directly into the ear canal like standard headphones, the sound reflects off the surface of the outer ear to create natural 3D sound. The S-Logic Plus technology also provides a lower dB output with the same perceived loudness. This means you can listen at lower volume levels, which may reduce the risk of hearing damage.
    The headphones come with 2 detachable cables, which use a B-Lock connection with gold-plated Neutrik plugs. The 5' cable has a 3.5mm angled stereo plug that's ideal for use with MP3 players, laptops, and other portable devices. The 10' cable has a 1/4" plug, which is perfect for use with A/V receivers, home stereos, and professional-level audio equipment.
    Made in Germany
    • The headphones are hand crafted in Germany with the highest attention to detail
    High-Quality Materials
    • Genuine Ethiopian sheepskin leather for the headband and ear cushions provides the ultimate softness, smoothness, and noise isolation. The housings have finely polished safety glass name plates to evoke a professional look. A custom-made case is provided for storing the headphones
    Exceptional Sound
    • The 40mm titanium-plated drivers have neodymium magnets to provide an ultra-wide frequency response to bring out the deepest bass and clearest treble in your music, ideal for monitor reference, engineering, mastering, and audiophiles
    S-Logic Plus Technology
    • Patented S-Logic Plus Natural Surround Sound technology uses decentralized drivers to create a spacious 3D sound experience that puts you right in the middle of the music. It also lets you listen at lower volume levels for the same perceived loudness, which may help reduce hearing damage
    ULE MU Metal Shielding
    • The Ultra Low Emission (ULE) shielding was designed with the professional in mind. Many pros spend the majority of their time wearing headphones. The special MU metal shielding helps to reduce radiation by up to 98% compared to other headphones
    Single-Sided Cables
    • The headphones come with 2 detachable cables, which use a B-Lock connection with gold-plated Neutrik plugs for convenient swapping. The 5' cable has a 3.5mm angled stereo plug that's ideal for use with MP3 players, laptops, and other portable devices. The 10' cable has a 1/4" plug, which is perfect for use with A/V receivers, home stereos, and professional-level audio equipment. The single-sided design helps to minimize snags and tangles
Subscribe
10% off Your First Order!
