V-MODA Crossfade 2 Closed-Back Wireless Over-Ear Headphones - headphones.com
Color
Matte Black
Matte White
Rose Gold
Listen on the go with a pair of V-MODA Crossfade 2 Wireless Headphones. These headphones play audio through 50mm dual-diaphragm drivers that have inner and outer rings to prevent bass notes from bleeding into higher frequencies. Japanese-made and engineered CCAW coils help preserve detail.
*The rose-gold version is built with Qualcomm aptX audio codec to enable higher bluetooth quality.
They connect to your device wirelessly via Bluetooth or with the included SpeakEasy cable with microphone and single-button remote. Controls and a microphone are also built into the headphones themselves for taking calls, pausing skipping music, and more.
Constructed for durability, the headphones feature a steel frame and headband and a CliqFold hinge that allows them to fold down to a compact size. The internal battery lasts for up to 14 hours and can be recharged with the included V-Micro USB cable. The included Exoskeleton case has ventilation holes, a carabiner clip to secure it, and a V-STRAP for cable organization. The Crossfade 2 Wireless are compatible with the BoomPro microphone, the SharePlay cable, the 3-button SpeakEasy mic cable, and the REMIX VAMP amplifier, as well as gaming systems.
Specs
Type Over-ear, closed back
Drivers 2" (50 mm)
Wireless Connectivity Bluetooth
Wireless Range 33' (10 m)
Frequency Response 5 Hz to 40 kHz
Sensitivity 100 dB @ 1 kHz, 1 mW
Microphone Sensitivity -42 dB @ 1 kHz
Impedance 32 Ohms
Connector 1 Micro-USB, female (charging)
Battery Size 430 mAh
Battery Life Up to 14 hours
Dimensions Not specified by manufacturer
Weight 10.9 oz (309.0 g)
Packing Info
Package Weight 1.8 lb
Box Dimensions (LxWxH) 7.4 x 6.1 x 4.7"
In The Box
Exoskeleton Carry Case
Carabiner Clip
Reinforced SpeakEasy 1-Button Microphone Control Cable
V-Micro USB Cable
Gold-Plated 1/4" Adapter
V-MODA Sticker
Limited 1-Year Warranty
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
Free Headphone Stand With Your First Order
