V-MODA Crossfade M-100 Closed-Back Over-Ear Headphones
Color
Matte Black
Shadow
White Silver
The Crossfade M-100 Headphones from V-MODA feature a design that was crowdsourced from multiple producers, DJs, and V-MODA. They have 50mm dual-diaphragm drivers that have been quality tested at six separate frequencies to assure consistency in performance. The M-100s have a steel frame and headband designed for durability. The memory-foam earpads provide a comfortable fit and help provide passive noise-isolation. You can mix two sources simultaneously to the M-100s by connecting individual sources to the inputs on both earcups.
The included Share Play cable allows you to share your music by providing a 1/8" input directly on the cable. This allows you to plug in another set of headphones to the same audio source without the need for an adapter. The SpeakEasy cable features a single-button remote and in-line microphone for taking phones calls on any smartphone with a 1/8" output. An exoskeleton carry case with carabiner clip is included.
No Batteries or Artificial Processing
  • Pure sound without the two extra digital-to-analog conversions of battery powered headphones
Consistent Driver Quality
  • The Crossfade's sound is quality tested at 6 frequencies
Dual Inputs & V-CORK
  • Mix two sources at the same time or daisy chain headphones with your friends; the included V-CORK seals & protects the unused input
SpeakEasy Mic Cable
  • Tuned for voice recognition and calls in the noisiest environments, the button control universally works with all 3.5mm smartphones and tablets including Apple, Android, Windows, Kindle and Blackberry
SharePlay Audio Cable
  • Share your music on a ride or DJ tandem without adapters
Tested Beyond MIL-STD-810G Test Standards
  • Kevlar Reinforced Cable/Plug Bend: Cables and 45-degree plug can bend over 1 million times
  • Concrete Drop: Survives 70+ drops on concrete from 6 feet
  • Headband Bend: Steelflex can bend 10+ times flat
  • Environmental: High and low temperatures, humidity, salt spray and UV exposure
CliqFold Hinge
  • Swiss-like hinge mechanism folds the headphones into the small exoskeleton carry case
V-STRAP System
  • Organize included cables and 1/4" adapter via the V-STRAP system inside the exoskeleton case, with extra room for your USB Flash Drive and earplugs
Specs
Type Over-Ear Circumaural
Drivers 2" (50 mm)
Frequency Response 5 Hz to 30 kHz
Sensitivity 103 dB @ 1 kHz, 1 mW
Microphone Sensitivity -42 dB @ 1 kHz
Impedance 32 Ω
Connector 1/8" (3.5 mm) 24K Gold-Plated
Weight 10 oz (280 g)
Packaging Info
Package Weight 1.65 lb
Box Dimensions (LxWxH) 7.4 x 6.1 x 4.6"
In The Box
V-MODA Crossfade M-100 Headphones
Exoskeleton Carry Case
Carabiner
Kevlar Reinforced SpeakEasy Microphone Control Cable
Kevlar Reinforced SharePlay Audio Cable
1/4" Pro Adapter
2 x V-CORK
V-MODA Sticker
Limited 2-Year Warranty
Subscribe
