V-MODA Crossfade Wireless Headphones
Color
Black
Chrome
Rouge
White Silver
The Crossfade Wireless Headphones from V-MODA feature a design that was crowd-sourced from multiple producers, DJs, and V-MODA. Utilizing years of research and development, the headphones offer exceptional wireless and wired performance with little difference in sound quality. The on-board Bluetooth capabilities allow you to pair the headphones with any compatible device up to 33' / 10m, while the simultaneous device pairing allows for connections to two devices at the same time. The internal battery supplies up to 12 hours of music playback and the 30 minute quick charge provides 3+ hours of playback.
The Crossfade Wireless has 50mm dual-diaphragm drivers that have been quality tested at six separate frequencies to assure consistency in performance. The headphone's construction features a steel frame and headband designed for durability. The memory-foam earpads provide a comfortable fit and help provide passive noise-isolation. You can mix two sources simultaneously to the Crossfades by connecting individual sources to the inputs on both earcups. The included SpeakEasy cable features a single-button remote and in-line microphone for taking phones calls on any smartphone with a 1/8" output. An exoskeleton carry case with carabiner clip is included.
Wireless Independence
  • Go the Distance: Pair your Bluetooth device and enjoy your headphones up to 33 feet (10 meters)
  • Simultaneous Device Pairing: Multitask and pair the headphones with two sources at a time, such as smartphone and laptop for work or smartphone and smartwatch for a workout
  • Unlimited Hours: Up to 12 wireless hours of music, 30 minute quick charge for 3+ wireless hours and unlimited hours in analog wired mode featuring virtually undistinguishable sound
  • Hybrid Wireless + Wired: Wireless for freedom, cabled when you run out of juice or demand zero latency pure analog audio for gaming, videos, music/DJ performance or a Hi-Fi DAC/AMP (connects to PS4 + Xbox One controllers)
Sound and Comfort
  • Master Crafted Materials: Superior lightweight metal components and 5+ years of comfort R&D
  • Immersive 3D Soundstage: Live performance experience
  • Clean Deep Bass: Feel and hear precise vibrations of your music without bloated boom or muddy mids
  • Ultra Wide Clarity & Vivid Midrange: Lifelike vocals, crystal clear cymbals and crispy hi-hats
  • Various Genres: Sound the way modern producer drum kits, samples and instruments were intended
  • Analog Purist Zero Latency: No powered EQ or colored sound that pollutes the audio and causes unacceptable latency for videos, gaming and DJ/music performance
  • Hybrid Wired/Wireless: For the first time Bluetooth headphones do not translate into low quality and sound virtually identical as analog wired mode
    Smartwatch Running Antenna: “Motivation without notifications” rigorously tested 1000+ km by V-MODA’s CEO with all smartwatches for the ultimate antenna performance
  • Ultimate Codecs: AAC+, AAC, MP3, SBC audio codecs in Bluetooth mode delivers hi-fi sound and maximum compatibility with all iOS, Android and notebook devices
  • 50mm Dual-Diaphragm Driver (Patent Pending): Inner and outer rings separate the bass from bleeding into the mids and highs
  • Analog Noise Isolation: Naturally cut the distractions of jet engines and unwanted noise without the hiss and pressure of ANC
  • No Battery Analog Mode: Powerful, pure sound without the pollution, latency and coloring of an artificial EQ
  • Minimal Sound Leakage: Immersive 3D sound for you without bothering others
  • Crystal Clear Communication: Hidden mic and included 1-Button SpeakEasy cable allows calls on-the-go under any circumstances
  • Consistent Driver Quality: Quality tested at 6 frequencies for stricter consistency than the competition, often by an order of magnitude
  • 5+ Years of Comfort R&D: A redesigned ergonomic platform based on headband and hexagon shape that goes even further in minimizing the force on your head, ears and gap for the best fit
  • BLISS Memory Foam Cushions: Naturally forms to your ears to provide supreme comfort and noise isolation (XL cushions available)
Versatility and Style
  • Mind the Gap: Patented sleek design frames the natural lines of your facial features and minimizes unsightly gap
  • Optional Custom Shield Kits: Optional 3D print or laser engrave your logo, change your shield material and color
  • Cable & Cushion Ecosystem: Extend your functionality with the optional BoomPro Mic for gaming and communication, XL Memory Cushions, CoilPro extended and a variety of optional cables add versatility to your wireless headphones
  • Auto Analog Switch: Plug a cable in the jack to automatically switch off all battery and electronics to turn your Bluetooth headphones into a “zero latency” weapon
  • Durability: Built to Last
  • STEELFLEX Headband made in vegan leather
Steel Frame
  • Tested Beyond Military-Level Quality MIL-STD-810G Test Standards
  • Durable Cable/Plug Bend: Cables and 45-degree plug can bend over 1 million times (100x industry standard)
  • Headband Bend: Steelflex can bend 10+ times flat
  • Environmental: High and low temperatures, humidity, salt spray and UV exposure
Portable Exoskeleton Case
  • Form-Fitting Case: Store your headphones and gear in the included hard-shell case
  • Exoskeleton V-STRAP: Organize cables and 1/4" adapter via the V-STRAP system with extra room for your USB Drive & Fader earplugs
  • Carabiner Clip: Secure your case on the outside of your bag for quick access
Detachable Cables
  • Built-In Mic: Hidden mic allows for calls and voice recognition in wireless mode
  • 1-Button SpeakEasy Mic Cable: Specially tuned for voice recognition and calls in the noisiest environments, the button control universally works with all 3.5mm smartphones and tablets including Apple, Android, Samsung, Windows, Kindle and Blackberry
  • V-Micro USB Cable
Specs
Type Over-Ear Bluetooth Wireless Headphones
Drivers 2" / 50 mm
Frequency Response 5 Hz to 30 kHz
Latency Wired Latency: 0 ms
Bluetooth Low-Power CSR BlueCore featuring Hi-Fi ACC+, ACC, MP3, SBC codecs and OTA Flash ROM upgradeable features
Battery Up to 12 hours music playback (depending on volume/music)
Sensitivity 107 dB @ 1 kHz, 1 mW
Microphone Sensitivity -42 dB @ 1 kHz
Impedance 30 Ohms
Weight 10.3 oz / 292.0 g
 Packaging Information
Package Weight 2.0 lb
Box Dimensions (LxWxH) 9.1 x 7.1 x 4.3"
In The Box
Exoskeleton Carry Case
Carabiner
Kevlar Reinforced SpeakEasy Microphone Control Cable
V-Micro USB Cable
V-MODA Sticker
Limited 1-Year Warranty
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
