Close Cart
Your cart is currently empty.
Browse:
Westone UM Pro 30 Westone UM Pro 30
  • Westone UM Pro 30
  • Westone UM Pro 30
  • Westone UM Pro 30
  • Westone UM Pro 30
  • Westone UM Pro 30
  • Westone UM Pro 30
Westone UM Pro 30
Westone UM Pro 30
$399.99
  • Low-profile, lightweight, universal earpiece which delivers maximum comfort and in-ear coupling for dynamic transfer of sound
  • Combines multiple balanced armature drivers with sophisticated crossover networks to provide clear detail and enhanced frequency range
  • Westone's EPIC replaceable cable is constructed of bifurcated, high-flex, ultra-low resistance tensile wire, reinforced with a special aramid fiber, and braided for ultimate durability, acoustic transparency, and isolation from mechanical cable noise
loading
Headphones.com accepts NANO, Bitcoin, Ethereum, Litecoin, TRON, Ark, Ethereum Classic and many more!
  • Description
    The Westone UM Pro 30 Triple-Driver with 3-Way Crossover In-Ear Monitor Headphones are designed and tuned for performing artists to provide professional-grade sound reproduction. They are used in various venues in applications such as theater, live shows, TV stations, and more. It can also be used for iPads, field recorders, and MP3 players. These triple-driver headphones feature a frequency response of 20 Hz to 18 kHz. They use separate bass, mid-range and high-frequency balanced armature drivers in conjunction with a 3-way crossover to provide a detailed listening experience. The replaceable cable connection is a braided EPIC cable. A weather-resistant vault case with foam interior, EPIC 50" removable cable, comfort ear tips, and cleaning tool are included.
  • Tech Specs
    Sensitivity
    124 dB SPL @ 1 mW
    Frequency Response
    20 Hz to 18 kHz
    Impedance
    56 Ω @ 1 kHz
    Noise Attenuation
    25 dB passive
    Driver
    Three balanced armature with passive 3-way crossover
    Cable
    EPIC removable cable and MFI G2 cable
    Cable Length
    50" (128 cm)
    Weight
    0.445 oz (12.7 g)
  • In The Box
    • Westone UM Pro 30 Triple-Driver with 3-Way Crossover In-Ear Monitor Headphones
    • Monitor Vault Case
    • Premium Comfort Ear Tips
    • 50" EPIC Replaceable Cable
    • Cleaning Tool
    • Limited 2-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
