Close Cart
Your cart is currently empty.
Browse:
Westone UM Pro 50 Westone UM Pro 50
  • Westone UM Pro 50 Headphones Westone Default Title
Westone UM Pro 50
Westone UM Pro 50
$649.99
  • Multiple balanced armature drivers with sophisticated crossover networks
  • Clear detail and enhanced frequency range
  • EPIC replaceable cable is constructed of bifurcated, high-flex, ultra-low resistance tensile wire, reinforced with a special aramid fiber, and braided for ultimate durability, acoustic transparency, and isolation from mechanical cable noise
airplanemode_active Free Shipping
refresh 365 Day Returns
money_offNo Tax
  • Description
    The Westone UM Pro 50 Five-Driver with 3-Way Crossover In-Ear Monitor Headphones are designed and tuned for performing artists to provide professional-grade sound reproduction. It is used in various venues in applications such as theater, live shows, TV stations, and more. It can also be used for iPads, field recorders, and MP3 players. This five-driver headphone features a frequency response of 20 Hz to 20 kHz. It uses separate bass, mid-range and high-frequency balanced armature drivers in conjunction with a 3-way crossover to provide a detailed listening experience. The replaceable cable connection is a braided EPIC cable. A weather-resistant vault case with foam interior, EPIC 50" removable cable, comfort ear tips, and cleaning tool are included.
  • Tech Specs
    Sensitivity
    115 dB SPL @ 1 mW
    Frequency Response
    20 Hz to 20 kHz
    Impedance
    45 Ω @ 1 kHz
    Noise Attenuation
    25 dB passive
    Driver
    Five balanced armature drivers with passive 3-way crossover
    Cable
    EPIC removable cable
    Cable Length
    50" (128 cm)
    Weight
    0.445 oz (12.7 g)
  • In The Box
    • Westone UM Pro 50 Five-Driver with 3-Way Crossover In-Ear Monitor Headphones
    • Monitor Vault Case
    • Premium Comfort Ear Tips
    • 50" EPIC Replaceable Cable
    • Cleaning Tool
    • Limited 2-Year Warranty
  • Reviews
    Customer Reviews
    No reviews yet
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
    0%
    (0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
