ZMF Eikon Over-Ear Wooden Headphones
Wood
Requires special order.
Usually takes up to 14 days for these finely crafted and perfectly tuned headphones to arrive at your doorstep!
The ZMF Eikons are simply amazing. They are comfy, they look beautiful and the sound will simply blow you away. Zach, the owner of ZMF headphones, created the Eikons after many years of experimenting with tuning, drivers and woods and we are glad he did because his finished product after so many years is one that will be staying in our collection for many years to come.
Zach chose TPE for its great resolving quality even when tuning the treble smoothly and linearly. He found bio-cellulose to have incredibly low distortion and that allowed him to tune more linearly while keeping the sound free of sibilance and hash.
ZMF's custom made drivers are made with extreme high quality. Heavy ABS housing, huge magnets, rubber surrounding the membrane for perfect dynamic movement, and 50mm size for low distortion, fast transients but with enough size to move the air needed for "oomph."
ZMF's drivers are pressure fit into our wood baffle sound chambers to provide super fast response, and absolute natural timbre.   The ZMF closed, vented sound chamber works as a perfected unit to provide you with a sublime listening experience.
  • From the adjustment risers to the infamous custom ZMF headpads and earpads, the ZMF original dynamics are made to fit each user just right
  • A closed, vented design allows owners to listen in peace in any environment. Leakage and privacy from outside sound is excellent.
  • Every Atticus and Eikon comes with a Seahorse SE-430 hard-case. These water-proof, dust-proof and life-proof cases will keep your investment secure.
  • By utilizing a special, natural, hand-wiped varnish, the Atticus and Eikon will have their wood protected and looking fabulous for years.
  • The ZMF Eikon driver. Meticulously crafted with a biocellulose driver membrane, rubber surround (for ultra low distortion), heavy ABS housing, and super heavy magnets. (final driver housing will be black)
  • Weighing in at almost 50g, this is the heaviest dynamic driver I've ever encountered. It shows in the sound too, with a powerful yet clean sound with an ultra black background.
  • Under the rear driver paper are 44 - one mm diameter vents for even air distribution. This makes for a sonic experience that is never boomy, yet fully musical.
  • The ZMF Atticus driver. A stiff molded plastic housing, TPE membrane (Thermo-plastic-elastomer), robust magnets and a heavier voice coil for very punchy, dynamic, smooth and fun sound.
  • IMPEDANCE: 300 OHMS
  • NET WEIGHT: CHERRY 490-530 grams; Padauk 550-600 grams
  • ZMF Eikon Biocellulose Driver Dynamic Headphone
  • ZMF Eikon Pads
  • Lambskin headband padding
  • Natural hand applied varnish
  • Stock Cable
  • S3 6500 Case
  • Owners Card
  • ZMF Eikon Pads
  • Stock Cable
  • S3 6500 Case
  • Owners Card
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Subscribe
