Buy Audeze iSINE 20 In-Ear Planar Magnetic Headphones - headphones.com
3 reviews
Cable
The Audeze iSINE 20 In-Ear Headphones use planar magnetic drivers which is absolutely crazy. They reproduce sound in a way that rivals top over ear headphones that cost thousands of dollars. The iSine 20's are huge upgrades over the iSine 10's. They have a longer Uniforce voice-coil that covers more of the nano-thin diaphragms, this creates better control and responsiveness for natural bass, clarity, and improved imaging. They are equipped with Planar drivers, Fluxor magnets, and ultra-thin diaphragms, and can be used with iPods, iPhones, and iPads.
These headphones include a pair of ear hooks and Earlocks for all-day comfort. They barely weigh .71 oz (20 grams) and are built with power-enhancing Fluxor magnets that double the magnetic driving force on the ultra-thin diaphragms. Their Uniforce voice-coil technology delivers an accurate in-ear headphone experience with distortion less than 0.1% overall, even at high volumes. In addition, the included Cipher Lightning cable contains a high-quality in-line amplifier, a digital-to-analog converter, and DSP, which delivers a vivid, natural sound.
Furthermore, customize your sound in real time with the Audeze iOS App. It features two presets to personalize your music playback. There is a 10-band equalizer that changes EQ in real time. You can refine the bass levels and tame the highs on peaky recordings. Then you can save two EQ curve presets that travel with the cable when switching devices.
Specs
Style In-ear, universal fit
Transducer Type Planar magnetic, semi-open
Magnetic Structure Fluxor
Magnet Type High-grade neodymium
Diaphragm Type: Ultra-thin Uniforce
Transducer Size 1.2" (30 mm)
Maximum Power Handling 3 W
Maximum SPL >120 dB
Frequency Response 10 Hz to 50 kHz
Total Harmonic Distortion (THD) <0.1% @ 100 dB
Impedance 24 Ohms
Cable Type Non-microphonic
Dimensions Not specified by manufacturer
Weight 0.71 oz (20 g) without cable
Packaging Information
Package Weight 1.05 lb
Box Dimensions (LxWxH) 10.2 x 6.9 x 2.9"
in the box
4.9' Audio Cable, 1/8" Stereo Plug Input to 2-Pin Plug Output
Limited 3-Year Warranty
Subscribe
10% off Your First Order!
