Meze
Meze Audio 99 Classics V2 Headphones
Regular price $349
Sale price $349 Regular price $349.00
1 of 9
Meze
Regular price $349
A Classic Fit for Today
The Meze Audio 99 Classics V2 marks the 10-year anniversary of one of the most beloved headphones in modern audio. Since their debut in 2015, the original 99 Classics became an icon for their warm, musical tuning and timeless walnut-wood design. The V2 continues that legacy with a refined acoustic balance, improved comfort, and full serviceability—built to last for decades, not product cycles.
Iconic Design, Thoughtfully Refined
Everything listeners loved about the original—its inviting tone, effortless comfort, and handcrafted materials—remains intact. Look closer, though, and you’ll find subtle yet meaningful evolutions: increased internal ear-cup volume, enhanced acoustic sealing, and a new clip-in earpad system that simplifies replacement while optimizing fit. It’s the same unmistakable silhouette, re-engineered for today’s listener.
Features & Craftsmanship
  • Walnut-wood ear cups — CNC-machined, hand-finished, and polished for lasting beauty and natural resonance.
  • Two tonalities — Optional acoustic absorbers let you shift from the balanced V2 tuning to the warmer signature of the original 99 Classics.
  • Self-adjusting headband — Spring-steel support and vegan-leather strap provide an even, pressure-free fit for every head shape.
  • Redesigned earpads — Medium-density foam with a six-point clip-in mount for easy replacement and improved seal.
  • Sustainable by design — Every component—drivers, headband, cables, ear cups—is user-replaceable for long-term serviceability.
  • Included accessories — Dual-twisted Kevlar-reinforced cable, 6.3 mm adapter, and USB-C DAC/amp dongle for modern setups.
Balanced, Natural Sound
The 99 Classics V2 adopts a more neutral tuning than its predecessor, improving separation, imaging, and overall soundstage while preserving the musical warmth that made the original famous. Enhanced sealing and re-engineered baffles deliver cleaner bass definition, smoother mids, and an airier top end—resulting in a presentation that feels both familiar and freshly refined.
Built for Listeners Who Value Longevity
Every detail of the 99 Classics V2 is designed to endure. From its sustainable construction to its replaceable components, this headphone embodies Meze Audio’s philosophy of “buy once, enjoy for life.” Whether for focused work, studio monitoring, or pure home listening, it offers a blend of sonic honesty, tactile luxury, and timeless style.
Specification Details
Driver Type Dynamic
Driver Size 40 mm
Frequency Response 15 Hz – 25 kHz
Impedance 16 Ω
Sensitivity 103 dB SPL / mW @ 1 kHz
Total Harmonic Distortion < 0.1 % @ 1 kHz
Input Connector Dual 3.5 mm TS jack
Ear Cups Solid Walnut Wood
Weight 290 g (10.23 oz)
Cable 1.8 m dual-twisted Kevlar-wrapped OFC with 3.5 mm jack
Included Adapters USB-C DAC/AMP dongle · 6.3 mm gold-plated jack adapter
Price $349 USD / €349 EUR MSRP
Compare to the Original 99 Classics
Feature 1st Generation (2015) 2nd Generation (2025)
Tuning Warm, V-shaped Balanced, neutral
Acoustic Sealing Standard Improved at all junctions for better isolation
Bass Port None Integrated into 3.5 mm jack shell
Ear Pads Stretch-skirt mount Clip-in mechanism with reshaped volume
Input Sockets 6 mm diameter 7 mm diameter (for wider cable compatibility)
Stock Cable(s) 1.2 m Kevlar w/ Mic · 3 m Kevlar OFC 1.8 m dual-twisted OFC · USB-C DAC/AMP dongle
Sound Technicalities Classic warmth Improved separation & soundstage
Frequently Asked Questions
How does the 99 Classics V2 differ from the original?
The V2 keeps the same iconic design but introduces ten refinements: improved sealing, neutral tuning, redesigned earpads, and upgraded cables for a cleaner, more balanced sound.
Is the V2 still made from real walnut wood?
Yes. Each ear cup is CNC-machined from solid walnut, then hand-finished, stained, and polished in Meze Audio’s Romanian workshop.
Can I replace parts or service the headphone myself?
Absolutely. Every component—ear pads, cables, headband, drivers—is replaceable. The 99 Classics V2 is designed for longevity and easy maintenance.
Who are these headphones best suited for?
They’re ideal for music lovers, content creators, and design-minded listeners who value tonal accuracy, warmth, and sustainable craftsmanship.
Customer Reviews
Overall rating: 4.2 / 5 from 5 reviews.
I have about 26 hours of listening with the V2 Classics. After one hour of listening with no EQ, I took Andrew‘s suggestion and used paper towels as a filter, and it made an incredible difference. It smoothed out the mid-treble, which allowed the higher mid-range and treble to shine. When I did EQ, along with my RNHP amp and Valhalla 2 as a pre amp, the V2’s opened up. It didn’t have the soundstage of a closed back. My baseline EQ is a Harman Curve representation that I use with my former daily driver. Yes, the V2 is now my go to. They are extremely comfortable, no heat build up, and I can wear them all day. I have a large head, but after a gentle stretch, I feel no clamp pressure. My ears are normal size and they fit well inside the cups. For me, the build quality is exceptional and, while I like the ability to replace parts on my own, I have a feeling I won’t need to for quite some time.
Customer photo review of Meze Audio 99 Classics V2 Headphones
My first Meze, so I had somewhat high expectations of quality and they were met. Comfort is great, my fat head fits just barely. The sound is good, if a bit spicy on the treble for my taste. This surprised me because the Edition XS doesn't bother me at all. The paper towel method fixed that though. The foam disk, while changing the sound in a way I also liked, made the space in the ear pad too small for my ears.
